Help me build a budget pc !!!
Dredae23
Hello, I'm building a Arcade cabinet and need help building a strong enough pc to run a lot of emulators . I want to be able to up to a ps2, dc,gamecube and etc. Please help !!!
Semi-Noob
My core i5 6600k, gtx 960 desktop run ps2/GC pretty good. I been playing Tales of Beseria on it no prob. Wouldnt go any lower then that but havent built a pc in awhile
Okay cool, any other specs?
I recommend you look up gaming PC builds from PC Mag, Toms Hardware etc... then check out their budget builds and use one of those or mix-n-match from those. They've already done the research, bought the parts and tested & benchmarked them so why try to guess and reinvent the wheel?
I use the Toms budget build from 2014 I think for mine, but gave it the next step up video card from their mid build and it came in around $400 or $500 and can emulate anything as well as run any PC games so far at 1080 and 120+ fps. It's an i3, R9 280 amd card with 8 gigs or ram (maybe 16 can't remember).
Another good option is to scour Ebay for corporate refurbs... lots of i5 machines out there for cheap, and most include a Windows license.
I wouldn't recommend buying refurbs ... you may go for only the used Graphic card, the rest of your build should be sealed.
I disagree... in my experience most corp refubs are incredibly gently used. Larger companies either lease or depreciate their PC equipment over 3 - 4 years, then dump them and refresh for tax reasons. They also typically come with a valid Windows pro license, which is worth $100 by itself. About a year ago I picked up a 4th gen i5 (3.2GHz) with a Windows 10 pro license for $185 all in. It came with 4GB of RAM (which I upgraded to 16GB), a 300GB HD (which I swapped for a SSD), and has a couple of PCIe slots (which I put a $50 video card in). The thing screams... total cost was probably $375. The power supply in it was even brand new.
If you're handy enough to disassemble and clean the components, and re-apply thermal grease, you're good to go.
