rottenpigz Posted August 4, 2017 Posted August 4, 2017 Running MAME .182, UltraStick 360 with USB joysticks, Gold Leaf buttons, I-Pac2 I have gone into MAME and selected a game then pressed the tab key and went through the config menu setting all the joysticks and buttons, however, when I exit out back to the wheel I cant move up or down to scroll through the games? Is there another config menu that I need to set up for that? Joystick and buttons work in a game. thanks!
Metalzoic Posted August 5, 2017 Posted August 5, 2017 Ultrastick 360s can be set up as joysticks and as a keyboard encoder I believe. HyperSpin doesn't work right with joysticks, which is why you 're supposed to keep joysticks, trackballs and spinners disabled in the control settings within HyperHq. Make sure you have the joysticks enabled boxes unchecked in there and use the keyboard control section instead. I'm thinking of upgrading my cab to U360s with the rotary stick added, so I'm interested in how you get it set up.
32assassin Posted August 6, 2017 Posted August 6, 2017 when you load a game in MAME; hit the tab key and configure your buttons through the MAME config menu. You are ONLY configuring how your joystick and buttons work IN MAME!!! you did not configure any buttons or joysticks to control your HyperSpin Wheel. You need to go into HyperHQ and configure your joystick and buttons in that Menu but has Metalzoic mentioned, joystick support is very flaky at best, use a 3rd party keyboard mapper or the start up script to map your joystick and buttons to control your Hyperpin wheel.
