HYPERSPIN UNRESPOSIVE WHEN PICKING SNES
Hardman
Ok so I had this problem some months ago I can load the SNES games from rlauncher and they work fine. When I open hyperspin when I select the SNES system from the main wheel the screen just stays black no sound I have to end the task to get out. All my other systems run fine and I have checked all the paths. I finally just completely re-downloaded hyperspin and rlauncher and it worked fine so I transferred over my media and bam doesn't work anymore again. Tried deleting the media and copying over the basic folder and still doesn't work. Anyone else have this problem really don't want to do all this over for a 3rd time. Thanks for any insight.
Or possibly a theme or artwork issue. The Sexy Parodius theme for mame still locks up HyperSpin if you download it from Sync, I then have to extract it and remove the flash element.
I second that, most likely a DB issue,  or maybe you have Start on Favorites = True in your settings.ini ,  but no Favorites.txt file in your Snes DB folder, that'l freeze it up too I believe..
Thanks guys i removed the artwork and put the base stuff that came with inital install and it started working again so guess i had some bad media.
