extracampine Posted January 1, 2018 Posted January 1, 2018 When I load up a theme to edit it in Hypertheme, it won't show the associated video anywhere, even when I "play" the theme. I have set the default video directory in the settings. Am I missing anything here? Edit: even worse, I edited a theme in HyperTheme to move an image, and saved it - and when I run the theme in HyperSpin the video isn't on the theme anymore!!
husko Posted January 1, 2018 Posted January 1, 2018 43 minutes ago, extracampine said: Edit: even worse, I edited a theme in HyperTheme to move an image, and saved it - and when I run the theme in HyperSpin the video isn't on the theme anymore!! because you saved the theme without adding a video. The video must be in FLV format to be able to play in Hypertheme (you can use any video to edit your theme)
extracampine Posted January 1, 2018 Author Posted January 1, 2018 But all my videos are in MP4. If I want to edit a theme, do I need to convert the video for that theme to FLV?
Honosuseri Posted January 1, 2018 Posted January 1, 2018 18 minutes ago, extracampine said: But all my videos are in MP4. If I want to edit a theme, do I need to convert the video for that theme to FLV? I'm pretty sure you can just rename it to *.flv. Once you're done with your theme you can rename it back to *.mp4 "There is so much more and beckons me. To look through to these, infinite possibilities..."
husko Posted January 1, 2018 Posted January 1, 2018 You don't necessarily have to use the video of the theme you are going to edit. A simple way is to make a video template to use for HT. The same video (.flv) can do the job for all your themes.
extracampine Posted January 1, 2018 Author Posted January 1, 2018 Thanks a lot, will try that. But wouldn't it be easier for Hypertheme to be able to use the same MP4 videos that Hyperspin actually uses!?
32assassin Posted January 1, 2018 Posted January 1, 2018 Hypertheme hasn't been updated since before Hyperspin go the MP4 upgrade and Hyperspin is still using some FLV videos transitions and your default Front End "Missing video" file I suggest you make a copy of this video C:\HyperSpin\Media\Frontend\Video\No Video.FLV and move the copy to your Hypertheme WIP folder C:\HyperSpin\HyperTheme\MyThemes\ when you are editing(or making a new theme) a theme, simply add the No Video.FLV from your Mythemes folder to your theme project as a video place holder.
extracampine Posted January 3, 2018 Author Posted January 3, 2018 Thanks for this. Wonder why Hypertheme hasn't been updated in so long, especially considering these issues.
