HS scanlines
Trnzaddict
Hey is anyone using HS’s built in scanline feature? Has anyone gotten it to actually look good? I’m running 1080p now so I can’t use my SLG3000 anymore and I’ve  even tried a 1080p scanline image and it looks like crap.
The scanlines are not scaled right, even when scaling is set to 1 they are too big and they are uneven.
Just wondering.
I am......Machine
Hey! I tested them a long time ago and saw the same thing as you do unfortunately; it might be able to look good playing a little bit with the scale, but don't know. Also, a good test could be if the software supports fake pngs, that is, to convert the scanlines image to swf, and then change its extension to png (like the special art is tricked for the Front End).
That’s true I forgot about that trick. I’ll try it out. If it’s doesnt look good I’ll just run HS with no scanlines. No biggie.
I am......Machine
