thenoob Posted February 7, 2018 Posted February 7, 2018 First off, apologize for the double post, but I’m having a few issues and need a few questions answered. ive got hyperspin running with Sega genesis and all is ok, I’m moving to Mame and I’m a bit hung up. 1. I’ve got a perfect Mame 0.139 set ready for Android. I’m in the understanding you have to have your romsets unzipped for Android. I’ve unzipped them properly and they are all in their seperate folders. now if I have this correctly, I have to go into Hyperspin/settings and adjust the “romextension” to match the unzipped rom extension? I’ve done this for genesis. Currently it’s “zip” obviously. My question is, when the Mame roms unzip , it’s not in a single file structure, so what extension do I add to the Settings confit so it will recognize the unzipped Mame roms? wow, that was a long question but I think it makes sense?? i have a few other ones but that’s my main issue. btw - I have followed the tutorials on here and d/l the Android hyperspin settings files and have overwritten them as told to.
thatman84 Posted February 7, 2018 Posted February 7, 2018 Unzip vs zipped is emulator specific. Mame roms should always be zipped. Chd games do have unzipped folders but thats it. For other systems like cd based consoles theres not much support for zipped files. Although compressed game formats do work like pbp, chd gzip (for gamecube). Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thenoob Posted February 7, 2018 Author Posted February 7, 2018 Problem solved I guess Can I do that for the other systems? I was under the impression that Android won’t support Zipped roms?
thenoob Posted February 7, 2018 Author Posted February 7, 2018 I’m mainly running old console systems no CD systems nes snes Sega Atari turbographx etc
thatman84 Posted February 7, 2018 Posted February 7, 2018 Check with whatever emulator your using. You can easily test it also. Just add zip to the .ini files Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thenoob Posted February 7, 2018 Author Posted February 7, 2018 I just did tried turbo graphix and snes both in zip, wouldn’t work, I’ll unzip and add the proper extension to the Ini, that’s In HS/settings correct? i tried this for snes last night, unzipped added sfc to the rom extension (that’s what my snes roms unzipped too) and it was a no go.
thatman84 Posted February 7, 2018 Posted February 7, 2018 For snes depending on what you named it mine is Hyperspin/Settings/Super Nintendo Entertainment System.ini it could be Hyperspin/Settings_Android which takes priority over the standard settings folder. i'm fairly certain sfc is fine and should work what emulator (what core if Retroarch)? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thenoob Posted February 7, 2018 Author Posted February 7, 2018 think I’ve got it figured out now except for mame im using the arcade 2010 (0.139) how do I write it in the parameters? pic for reference
whiskeyriver Posted February 10, 2018 Posted February 10, 2018 cores/mame2010_libretro_android.so Make sure you have downloaded the Mame 2010 core in RetroArch for this to work.
whiskeyriver Posted February 10, 2018 Posted February 10, 2018 Also forgot to mention...with that particular romset, you could just download mame4droid and leave the “parameters” field blank and type the following in the “exe” field: exe=com.seleuco.mame4droid/com.seleuco.mame4droid.MAME4droid Either way, you should be good ?
thenoob Posted February 11, 2018 Author Posted February 11, 2018 I’ll try this i want to use retroarch because of the shaders ive got Mame working fine in Retroarch just gotta figure out why it’s not launching in HS again, I click on the game to launch, screen flickers, then just defaults back to the game select page I was just on. It’s working fine inside retroarch.
thenoob Posted February 11, 2018 Author Posted February 11, 2018 Here’s how my settings INI looks like , everything looks fine to me. All my roms ate correctly setup in the correct folders as instructed.
thenoob Posted February 11, 2018 Author Posted February 11, 2018 Fixed! noticed there was a double line for parameters and also rompath needed to be set to true. one weird thing, HS ALWAYS crashes when I go on Mario titles in nes and Super Nes, it’s really, really weird.
thatman84 Posted February 12, 2018 Posted February 12, 2018 Glad you sorted it, the mario thing is 1 of a few things. Incompatible game theme corrupt image file bad database xml entry Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thenoob Posted February 12, 2018 Author Posted February 12, 2018 Ya it’s weird all my sets are from PD, perfect working order what I’ll gO through those one by one. i do have one question tho, i do have some custom shader packs and overlays, where on RA android do they go? I browse the RA folder structure and don’t see any folders anywhere to import custom shaders and overlays (bezels) into. thanks for all your help, being handy with Hs already made this a pretty painless setup.
thatman84 Posted February 12, 2018 Posted February 12, 2018 You can point ra to your folders under Settings > Directory I put new folders in the Retroarch folder and then download the defaults from online updater Some info here Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thenoob Posted February 12, 2018 Author Posted February 12, 2018 I see i think I’m confused between the 2 retroarch folders com.retroarch and the Retroarch main folder ill watch the video
thatman84 Posted February 12, 2018 Posted February 12, 2018 Com.retroarch just has the main config files in and thats it Retroarch main folder has all the user files in like saves and override configs Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thenoob Posted February 12, 2018 Author Posted February 12, 2018 So if your set your overlay to the main retroarch folder ive created a folder called overlays all my mame overlays are in a folder called “mame” they are unzipped but named correctly as the XML. will retro arch scan the sub folder “mame” inside “overlays”? I’m obviously going to setup console overlays as well but really want to figure out how the folder structure needs to be. and do you have to set these up “per core?”
thenoob Posted February 12, 2018 Author Posted February 12, 2018 So I’ve been able to get the default retroarch overlay to show. how do i get the mame overlays to show, this shouldn’t be that difficult. Folder is pointed to the correct location. the CFG file for each overlay is in the overlay folder with the overlay artwork for each game. Do the CFG files need to be moved? what am I doing wrong? The default retroarch overlay shows , doesn’t matter what Mame game I run.
thatman84 Posted February 12, 2018 Posted February 12, 2018 Overlays currently have to be set per core or per game basis. Folder structure is not important really. You have to manually point Retroarch to the .cfg file with your overlay image and save it on core/game basis I have a topic on batch files that could help. Search batch and my name. For MAME you can just use mame formatted sets and so long as the name matches it will work more automatically like PC MAME Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thenoob Posted February 17, 2018 Author Posted February 17, 2018 Thanks everything has been going on except for today my nvidia Shield gamepad all of a sudden cannot exit retroarch/hyperspin ie quit a game. Is there a way to reset to the defaults? I know the shield controller should override but I’m having issues thanks
