Peliculon Posted March 4, 2018 Posted March 4, 2018 Hi to all, I have some troubles with MAME version 0.139, because can't run in PC (Hyperspin 1.4.0.0 with RocketLauncher 1.0.1.7 and HyperHQ 1.3.0.0) for some reason and I don't know how to fix that. I was looking the .ahk availables and I think that the problem is this, because MAME.ahk was created for versions .160. I hope that someone with knowledge about Autohotkey could create the MAME.ahk for 0.139 (and all neccesary archives) and share here in this thread. Im buildng a dual HDD with Hyperspin for PC and Android. I really need that MAME.ahk for MAME version 0.139, because if not, then will be neccesary duplicate the MAME media files and roms and install two versions of MAME (one for PC and the other version for MAME4Droid in Android = 0.139u1). At the moment Im development the MAME.xml for the complete romset of 0.139 and uff a lot of work (i'll upload here when i finish). Anyways, i think that i'll go to install two versions for MAME, but could be awesome if someone create that MAME 0.139.ahk and make works too in PC with Hyperspin, because in Android works 100%.
Spawk Posted March 4, 2018 Posted March 4, 2018 Hi to all, I have some troubles with MAME version 0.139, because can't run in PC (Hyperspin 1.4.0.0 with RocketLauncher 1.0.1.7 and HyperHQ 1.3.0.0) for some reason and I don't know how to fix that. I was looking the .ahk availables and I think that the problem is this, because MAME.ahk was created for versions .160. I hope that someone with knowledge about Autohotkey could create the MAME.ahk for 0.139 (and all neccesary archives) and share here in this thread. Im buildng a dual HDD with Hyperspin for PC and Android. I really need that MAME.ahk for MAME version 0.139, because if not, then will be neccesary duplicate the MAME media files and roms and install two versions of MAME (one for PC and the other version for MAME4Droid in Android = 0.139u1). At the moment Im development the MAME.xml for the complete romset of 0.139 and uff:morning2: a lot of work (i'll upload here when i finish). Anyways, i think that i'll go to install two versions for MAME, but could be awesome if someone create that MAME 0.139.ahk and make works too in PC with Hyperspin, because in Android works 100%.You can run ANY version of mame you like. What you need is an xml (database) based off of 139 because the one hosted here will be for latest version.Sent from my SM-A520W using Tapatalk
Peliculon Posted March 4, 2018 Author Posted March 4, 2018 10 minutes ago, Spawk said: You can run ANY version of mame you like. What you need is an xml (database) based off of 139 because the one hosted here will be for latest version. Hummm, I don't think so. I created a new xml with HyperROM2XML tool and Hyperspin still showing a black screen when i try to launch a game from MAME 0.139, with the msg: "There was an error waiting for the window "ahk_classMAME". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem" The emulator for MAME 0.139 works fine, the problem is when i try to load a rom with Hyperspin, just show a black screen and that error msg.
Spawk Posted March 4, 2018 Posted March 4, 2018 Hummm, I don't think so. I created a new xml with HyperROM2XML tool and Hyperspin still showing a black screen when i try to launch a game from MAME 0.139, with the msg: "There was an error waiting for the window "ahk_classMAME". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem" The emulator for MAME 0.139 works fine, the problem is when i try to load a rom with Hyperspin, just show a black screen and that error msg. Oh... in RL module make sure "legacy" is selected when using an older mame.Sent from my SM-A520W using Tapatalk
Peliculon Posted March 4, 2018 Author Posted March 4, 2018 6 minutes ago, Spawk said: Oh... in RL module make sure "legacy" is selected when using an older mame. Thanks a lot! Working perfectly now Yeaahh!!
thatman84 Posted March 4, 2018 Posted March 4, 2018 This thread has a good 139 xml I never did finish that project. Just point a newer set at the retroarch core and generally it works for now. One day I will get it all finished Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Peliculon Posted March 4, 2018 Author Posted March 4, 2018 8 hours ago, thatman84 said: I never did finish that project. Just point a newer set at the retroarch core and generally it works for now. One day I will get it all finished Nice! The xml version that im creating is for 0.139 (not for 0.139u1), the reason is because I have that romset 100% complete (roms, chd and samples) and because i didn't find whats the difference between 0.139 and 0.139u1. I guess that "u1" come from "update 1", but i couldn't find that update in the web (just the update from 0.139 to 0.140 so...).
