menacegtr Posted March 14, 2018 Posted March 14, 2018 Hi to you all. I have been away for a while concerning hyperspin but just started using it as of today. My problem is when trying to load a genesis game in hyperspin i keep getting this error cannot find E:\hyperspin\modules\Sega Genesis\.ahk. please create one or use Hyperlist IN Rocketlauncher i have my rom path set correct, my emulator path set correct and when i audit the games and try one it loads up no problem but in hyperspin i get thee above message. So can somebody please explain in a bit of detail how to fix this so i can understand, hyperspin is confusing at best. I hope someone can please help. On a side note, i have mame set up and it works flawless regards Dave
thatman84 Posted March 14, 2018 Posted March 14, 2018 Sounds like you have not linked Hyperspin and Rocketlauncher correctly. Check the official videos in my signature. Iirc its the Hyperlaunch path in your settings.ini that needs pointing to rocketlauncher.exe (not rocketlauncherUI.exe) Also hyperspin has to be set as your active and default frontend in RL. Also explained in one of the 1st videos Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
menacegtr Posted March 14, 2018 Author Posted March 14, 2018 Thanks for the reply. Is the video in emulationguide.com. I am not sure which one it is. Sorry for my stupidity Is it this one Install Hyperspin & RocketLauncher
thatman84 Posted March 14, 2018 Posted March 14, 2018 This one My sig says "Official Hyperspin Tutorials" Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
menacegtr Posted March 14, 2018 Author Posted March 14, 2018 Ok thanks for that. I have done what is advised but here is now what is totally weird. All my Hyperspin, Rocketlauncher files are all on my E drive. In my Settings INI file i have Hyperlaunch_Path=E:\RocketLauncher\RocketLauncher.exe, before it was showing on D but when i launch a game it comes up as E:\RocketLauncher\RocketLauncherUI\Datadases\MAME\MAME.xml. But before all the problems started my original INI setting looked like D:\RocketLauncher\RocketLauncher.exe yes D drive. I have nothing pointing to D drive whatsoever, no hyperspin or rocketlauncher files at all. But hyperspin mame runs in this settings INI config on D so i don't know why the hell it wont work were all my Hyperspin, Rocketlauncher files are on My E drive. I have no clue as to what to do E:\RocketLauncher\RocketLauncher.exe,
thatman84 Posted March 14, 2018 Posted March 14, 2018 I'm really sure what the issue is. I can only suggest running through the video again and double checking all your settings are correct. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
menacegtr Posted March 14, 2018 Author Posted March 14, 2018 Ok Thanks for trying to help but it still does the same thing. Giving up using HP i will just use the emulator on its own. I use Fusion, Or is it Kega Fusion and just run it from there. Thanks again for your help Dave
gigapig Posted March 14, 2018 Posted March 14, 2018 You should post you Hyperspin and RocketLaucher logs via pastebin.
menacegtr Posted March 15, 2018 Author Posted March 15, 2018 @gigapig Can you please explain what you mean about pastebin, and how do i use it, sorry i have no clue on that
thatman84 Posted March 15, 2018 Posted March 15, 2018 Pastebin is a website you can copypaste your log text to and then post a link here to it instread of a wall of text which is hard to read. Its free Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
