djtale Posted March 30, 2018 Posted March 30, 2018 Hello, I'm very sorry if that question was already asked or explained, or if it is not posted in the correct forum. I'm starting to play with Hyperspin + HyperLaunch + Retroarch. I have already setup a system with EmulationStation+Retroarch and now I'm trying to move to Hyperspin. I have installed hyperspin 1.3.3. I have downloaded RocketLauncher.0.0.9 and have installed in a folder under Hyperspin. I wanted to run Atari 5200 roms with Retroarch. But when I look at retroarch.ahk (located in Hyperspin\HyperLaunch\Modules\Retroarch), it seems like this emulator is not included eventhough I can download atari800_libretro.dll from retroarch. But if I look at Retroarch.ahk located in Hyperspin\Modules\Retroarch), Atari 5200 is present. So I would like to understand that difference between HL2 and RL. How can I use all the cores available in Retroarch with RL ? Also, in HyperHQ, if I configure extensions for a wheel, let's say 'zip,7z,nes', when I run Hyperspin\HyperLaunch.exe (HL2), it seems like the system is searching for rom_name.zip.7z.nes instead of rom_name.zip OR rom_name.7z OR rom_name.nes Thank you very much.
Spawk Posted March 30, 2018 Posted March 30, 2018 Hello, I'm very sorry if that question was already asked or explained, or if it is not posted in the correct forum. I'm starting to play with Hyperspin + HyperLaunch + Retroarch. I have already setup a system with EmulationStation+Retroarch and now I'm trying to move to Hyperspin. I have installed hyperspin 1.3.3. I have downloaded RocketLauncher.0.0.9 and have installed in a folder under Hyperspin. I wanted to run Atari 5200 roms with Retroarch. But when I look at retroarch.ahk (located in Hyperspin\HyperLaunch\Modules\Retroarch), it seems like this emulator is not included eventhough I can download atari800_libretro.dll from retroarch. But if I look at Retroarch.ahk located in Hyperspin\Modules\Retroarch), Atari 5200 is present. So I would like to understand that difference between HL2 and RL. How can I use all the cores available in Retroarch with RL ? Also, in HyperHQ, if I configure extensions for a wheel, let's say 'zip,7z,nes', when I run Hyperspin\HyperLaunch.exe (HL2), it seems like the system is searching for rom_name.zip.7z.nes instead of rom_name.zip OR rom_name.7z OR rom_name.nes Thank you very much.Couple of things:Hyperlaunch is old. Not updated anymore. RocketLauncher is new and updated regularily.In HQ, "launch method - hyperlaunch" refers to either hyperlaunch or rocketlauncher. Just make sure the path in settings.ini is pointing to which ever one you use.Sent from my SM-A520W using Tapatalk
Spawk Posted March 30, 2018 Posted March 30, 2018 Couple of things:Hyperlaunch is old. Not updated anymore. RocketLauncher is new and updated regularily.In HQ, "launch method - hyperlaunch" refers to either hyperlaunch or rocketlauncher. Just make sure the path in settings.ini is pointing to which ever one you use.Sent from my SM-A520W using TapatalkOh, also i would not install Rocketlauncher inside the HS folder. Give it its own folder.Sent from my SM-A520W using Tapatalk
