LarryLaffer75 Posted May 14, 2018 Author Posted May 14, 2018 Ok, the Amiga is working. But Nestopia does not work, because of the .dll files?
Spawk Posted May 14, 2018 Posted May 14, 2018 Ok, the Amiga is working. But Nestopia does not work, because of the .dll files?I cannot read your language but d3d is direct draw. If it runs outside RL fine then you may have to set proper video mode in RLUI (openGL???)Sent from my SM-A520W using Tapatalk
Bungles Posted May 15, 2018 Posted May 15, 2018 Then download the dll and put it places. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
LarryLaffer75 Posted May 15, 2018 Author Posted May 15, 2018 Ok, everything is working now. But i have problems with Hyperspin, after starting HS and pushing the controler up or down, the wheel is spinning and spinning. I cant choose a game or anything else. What do i have to do?
thatman84 Posted May 15, 2018 Posted May 15, 2018 56 minutes ago, LarryLaffer75 said: Ok, everything is working now. But i have problems with Hyperspin, after starting HS and pushing the controler up or down, the wheel is spinning and spinning. I cant choose a game or anything else. What do i have to do? You cannot use a controller with Hyperspin directly (HyperHQ) settings. I believe everyone uses Joy2key or xpadder to convert your controllers to keyboard key presses to workaround to broken controller support Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
LarryLaffer75 Posted May 15, 2018 Author Posted May 15, 2018 Yes, me too. I use the Controller of my cabinet with xpadder and joy2key. What do i have to seup? In hyperhq or Rocketlauncher? I can send tomorrow a shot video of my problem.
Spawk Posted May 15, 2018 Posted May 15, 2018 Yes, me too. I use the Controller of my cabinet with xpadder and joy2key. What do i have to seup? In hyperhq or Rocketlauncher? I can send tomorrow a shot video of my problem.It's xpadder OR joytokey. No need to ever use both, they serve the same purpose.Sent from my SM-A520W using Tapatalk
thatman84 Posted May 15, 2018 Posted May 15, 2018 1 hour ago, LarryLaffer75 said: Yes, me too. I use the Controller of my cabinet with xpadder and joy2key. What do i have to seup? In hyperhq or Rocketlauncher? I can send tomorrow a shot video of my problem. I'm not sure, dont have a pc setup. I would say disable all joysticks in HyperHQ and double check your joy2key settings Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
LarryLaffer75 Posted May 17, 2018 Author Posted May 17, 2018 here (hope) you can see my problem. After using the cabinet control panel, hyperspin is spinning and spinning, i can not do anything.. 20180517_175418.mp4
LarryLaffer75 Posted May 18, 2018 Author Posted May 18, 2018 Is there nobody who can help me? I am going crazy
Spawk Posted May 18, 2018 Posted May 18, 2018 Is there nobody who can help me? I am going crazy I did not look at the video but the spinning sounds like you still have joystick enabled in HQ... you are not giving us much to work with here. Do you have joytokey or xpadder setup??? Or it is possible thats attract mode kicking in? (you can also disable that in HQ)Sent from my SM-A520W using Tapatalk
LarryLaffer75 Posted May 18, 2018 Author Posted May 18, 2018 Yes, Joystick is enabled. Otherwise i can not spin the Hyperwheel. In HyperHQ i have joytokey enabled. What Infos do you need. I can make pictures of my settings.
Spawk Posted May 18, 2018 Posted May 18, 2018 You cannot use a controller with Hyperspin directly (HyperHQ) settings. I believe everyone uses Joy2key or xpadder to convert your controllers to keyboard key presses to workaround to broken controller supportThatman tried to tell you already. You need to disable joystick in HQ and use a keymapper. I have a tutorial here on site for integrating joytokey with rocketlauncher. Should give you a good idea of what needs to be done.Sent from my SM-A520W using Tapatalk
LarryLaffer75 Posted May 18, 2018 Author Posted May 18, 2018 In HyperHQ i use the hyperspin startup script. When I disable the Joysticks in HyperHQ the Panels does not work anymore.
Spawk Posted May 18, 2018 Posted May 18, 2018 In HyperHQ i use the hyperspin startup script. When I disable the Joysticks in HyperHQ the Panels does not work anymore. ??? So you use the startup script, xpadder, joytokey, and have it enabled in HQ? Lol, how about you choose just one option for navigation and disable the rest.And I dont know what you mean by panels.Sent from my SM-A520W using Tapatalk
LarryLaffer75 Posted May 18, 2018 Author Posted May 18, 2018 I misunterstood you. I only use hyperspin startup script. With Panels i mean the controlers of my cabinet.
thatman84 Posted May 18, 2018 Posted May 18, 2018 @LarryLaffer75 please post screenshots of all controls tabs in HyperHQ? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
LarryLaffer75 Posted May 19, 2018 Author Posted May 19, 2018 Found the tutorial of Spawk. I will do step by step configuring joytokey and send the all my setups and some Infos of the cabinet,... At first a very big THANK to all who trying to help me.
LarryLaffer75 Posted June 1, 2018 Author Posted June 1, 2018 So, now i send some pics of my configuration. Please tell me, if you need more information. HS runs on Windows10, HS Version 1.3.2.0
Spawk Posted June 1, 2018 Posted June 1, 2018 On that second pic you have the direction keys set but I do not see the "enter" key anywhere! Enter starts the game.Sent from my SM-A520W using Tapatalk
LarryLaffer75 Posted June 1, 2018 Author Posted June 1, 2018 I f....d up here. I made the HS update and now HS find no Launcher. To Enter a game is not my problem. I cannot choose a game, because the shit wheel is spinning all the time and i cannot stop it.
Spawk Posted June 1, 2018 Posted June 1, 2018 Again, the wheel spinning is because "joystick" is enabled in HQ! Turn it off, we are trying to set up joytokey to fix that.Also another 1 of your pics shows trying to load xpadder??? Xpadder and joytokey do the exact same thing, no need to have both. I f....d up here. I made the HS update and now HS find no Launcher. To Enter a game is not my problem. I cannot choose a game, because the shit wheel is spinning all the time and i cannot stop it.Sent from my SM-A520W using Tapatalk
