ajhous44 Posted June 21, 2018 Posted June 21, 2018 Hello all, I can launch games through rocket launcher fine but in hyperspin nothing happens, not even an error message that I cannot find the rocketlauncher exe. Yes, my settings point exactly to the correct location including RocketLauncher.exe and I followed all steps twice through in the tutorial so I am very lost and confused. Any help would be greatly appreciated! EDIT: If you would like to see log files please inform me how to get those.
Spawk Posted June 21, 2018 Posted June 21, 2018 If they run through RL that's the main thing... and that still sounds like your not connected to RL properly though. Double check the path! May even need to be wrapped in quotes if there are spaces in the path name, not too sure. HS set as active and default FE in RLUI? Default FE path set to hs.exe in RLUI? Not sure what else could cause this.
ajhous44 Posted June 21, 2018 Author Posted June 21, 2018 yes - all correct - have checked 3 times as well as a bud of mine has taken a look too. Have tried 3 reinstalls. I'm right there with you - completely lost!
Spawk Posted June 21, 2018 Posted June 21, 2018 Set your RL log to "troubleshooting", try to run a game, then use pastebin (google it, it is better than pasting a huge log into post) to post it here.@Agent47 is a wizard with logs!*remember to turn the troubleshooting log off after you find the problem as it slows things down considerably when on.Sent from my SM-A520W using Tapatalk
ajhous44 Posted June 21, 2018 Author Posted June 21, 2018 Here is the link to the pastebin: https://pastebin.com/uAH580KB I believe the error starts around line 54: First it says it's not qualifiable for multigame? Then the next 3 times I hit enter it says rom not found.... but I can launch through rocketlauncher....?
Spawk Posted June 21, 2018 Posted June 21, 2018 Sorry I am at work for next 5-6 hours.I am no expert but that log looks fine to me... and you say they run from RL fine so that still leads me to believe its an HQ setting.You didnt select "normal" launch did you?Do not put the emulator path or parameters in HQ!You do need the rompath and extension set if you are using any filters though.Sent from my SM-A520W using Tapatalk
ajhous44 Posted June 22, 2018 Author Posted June 22, 2018 Nope. All is as should be. Just double checked...
griffin518 Posted June 22, 2018 Posted June 22, 2018 Will you post a copy of your hyperspin log? Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
ajhous44 Posted June 22, 2018 Author Posted June 22, 2018 3 hours ago, griffin518 said: Will you post a copy of your hyperspin log? 07:21:46 PM | HyperSpin Started 07:21:46 PM | Going FullScreen 07:21:46 PM | Checking for updates 07:21:46 PM | Update Check Complete 07:21:46 PM | Startup program unavailable 07:21:46 PM | Playing intro video 07:21:48 PM | Error intializing joysticks 07:21:48 PM | Menu Mode is multi 07:21:48 PM | Loading Main Menu.xml 07:21:48 PM | Main Menu.xml successfully loaded 07:21:49 PM | Main Menu wheel loaded successfully 07:21:50 PM | Main Menu wheel loaded successfully 07:21:50 PM | Main Menu wheel loaded successfully 07:21:52 PM | Loading MAME.xml 07:21:52 PM | roms_only is true, checking files 07:21:52 PM | Main Menu.xml successfully loaded 07:21:52 PM | MAME wheel loaded successfully 07:21:53 PM | Launching Game 07:21:53 PM | Using HyperLaunch 07:21:53 PM | Getting Launcher path 07:21:53 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:53 PM | Running Launcher 07:21:53 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:55 PM | Launching Game 07:21:55 PM | Using HyperLaunch 07:21:55 PM | Getting Launcher path 07:21:55 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:55 PM | Running Launcher 07:21:55 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:56 PM | Launching Game 07:21:56 PM | Using HyperLaunch 07:21:56 PM | Getting Launcher path 07:21:56 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:56 PM | Running Launcher 07:21:56 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:56 PM | Launching Game 07:21:56 PM | Using HyperLaunch 07:21:56 PM | Getting Launcher path 07:21:56 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:56 PM | Running Launcher 07:21:56 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:56 PM | Launching Game 07:21:56 PM | Using HyperLaunch 07:21:56 PM | Getting Launcher path 07:21:56 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:56 PM | Running Launcher 07:21:56 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:56 PM | Launching Game 07:21:56 PM | Using HyperLaunch 07:21:56 PM | Getting Launcher path 07:21:56 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:57 PM | Running Launcher 07:21:57 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:57 PM | Launching Game 07:21:57 PM | Using HyperLaunch 07:21:57 PM | Getting Launcher path 07:21:57 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:57 PM | Running Launcher 07:21:57 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:57 PM | Launching Game 07:21:57 PM | Using HyperLaunch 07:21:57 PM | Getting Launcher path 07:21:57 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:57 PM | Running Launcher 07:21:57 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:57 PM | Launching Game 07:21:57 PM | Using HyperLaunch 07:21:57 PM | Getting Launcher path 07:21:57 PM | Launcher located at C:\Hyperspin\RocketLauncher\RocketLauncher.exe 07:21:57 PM | Running Launcher 07:21:57 PM | Launcher Command Line is: C:\Hyperspin\RocketLauncher\RocketLauncher.exe "MAME" "pacman" 07:21:58 PM | Loading Main Menu.xml 07:21:58 PM | Main Menu.xml successfully loaded 07:21:59 PM | Main Menu wheel loaded successfully 07:22:01 PM | Exit program unavailable 07:22:01 PM | Quiting Hyperspin 07:22:01 PM | Bye! It is literally just not launching! It says launch game, and nothing happens.
