ChuckW Posted July 10, 2018 Posted July 10, 2018 First of all, I want to thank this forum for all of the info. It was a great help in me getting things setup. I have most things working properly but am having an issue launching SNES games, Gameboy and a few other consoles. NES, MAME and all Sega seem to work fine. I have tried to launch the games in Retroarch directly and they work fine. My current setup has Hyperspin running off of a USB drive. My log.txt doesn't seem to be updating, here is all it says, and the times haven't updated in hours. 07:00:23 AM | HyperSpin Started 07:00:23 AM | Going FullScreen 07:00:24 AM | Checking for updates 07:00:24 AM | Update Check Complete 07:00:24 AM | Startup program: HyperSpin Startup Script.exe 07:00:24 AM | Startup params not set 07:00:24 AM | Working directory: S:\Hyperspin\Scripts\ 07:00:24 AM | Window State: NORMAL 07:00:24 AM | Launching HyperSpin Startup Script.exe 07:00:24 AM | Command Line is HyperSpin Startup Script.exe 07:00:42 AM | Playing intro video 07:01:03 AM | Error intializing joysticks 07:01:03 AM | Menu Mode is multi 07:01:03 AM | Loading Main Menu.xml 07:01:04 AM | Main Menu.xml successfully loaded 07:01:06 AM | Main Menu wheel loaded successfully 07:02:27 AM | Exit program unavailable 07:02:27 AM | Quiting Hyperspin 07:02:27 AM | Bye! My HyperLaunch.log says > 10:20:53 AM | HyperLaunch v2.25c 10:20:53 AM | System Specs: HyperSpin Dir: S:\Hyperspin OS: WIN_7 OS Language: 0409 OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1280x1024 (1280x984 work) HyperSpin Res: 800x600 AHK Version: 1.1.07.03 10:20:53 AM | HyperLaunch launched directly 10:23:02 AM | HyperLaunch received "Super Nintendo Entertainment System" and "7th Saga, The (USA)" 10:23:03 AM | INI Keys read 10:23:03 AM | Checking paths 10:23:05 AM | Cannot find: S:\Hyperspin\Modules\Super Nintendo Entertainment System\Super Nintendo Entertainment System.ahk You do not have a HyperLaunch 2 module for Super Nintendo Entertainment System. Please create one or check HyperList. I checked the Modules folder and the SNES directory contains 4 AHK files, I created a copy of the SNES9x one and renamed it just as above, wasn't sure if that would help.
thatman84 Posted July 10, 2018 Posted July 10, 2018 This looks like a PC log and setup?? Where does shield tv come into play? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ChuckW Posted July 10, 2018 Author Posted July 10, 2018 I pulled those off the USB drive that's running Hyperspin on my Nvidia Shield. I followed these instructions. **link deleted** Instead of installing on my main 16GB drive I installed onto a USB drive. I downloaded Retroarch and all the cores, and most of the systems seem to run just fine.
thatman84 Posted July 10, 2018 Posted July 10, 2018 1 minute ago, kerflug said: I pulled those off the USB drive that's running Hyperspin on my Nvidia Shield OK, those are from the last time you run it on a PC I guess. Not gonna help for the Shield side I'm afraid Logs are a pain to get on android What specific issues do you have on the Shield? Click on a game and nothing happens, an error, can't get into the games list etc Need as much specifics on the issues. One system at a time Most problems are related to the .ini file for each system. Capitals in the wrong place or maybe referencing the wrong retroarch core Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ChuckW Posted July 10, 2018 Author Posted July 10, 2018 Click on game and screen goes black for about 2 seconds then brings me back to the wheel. Go to Retroarch directly and run game without issue. I was going to try and different core, but if it runs on Retroarch I'm guessing it isn't the core.
ChuckW Posted July 10, 2018 Author Posted July 10, 2018 Here is the SNES ini file. I thought the H:\ might be causing an issue given it's referenced as S: everywhere else, but that's the same way it's referenced in the other systems that run correctly. [exe info] path=H:\hyperspin\emulators\Super Nintendo Entertainment System\ rompath=Roms/Super Nintendo Entertainment System/roms/ userompath=true exe=com.retroarch/com.retroarch.browser.retroactivity.RetroActivityFuture romextension=sfc parameters=cores/bsnes_mercury_performance_libretro_android.so searchsubfolders=false pcgame=false winstate=HIDDEN hyperlaunch=true Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global CPWizard_Enabled=use_global CPWizard_Delay=use_global CPWizard_Params=use_global Fade_In=use_global Fade_Out=use_global Fade_Color=use_global Fade_In_Duration=use_global Fade_Out_Duration=use_global Fade_In_Delay=use_global 7z_Enabled=use_global 7z_Extract_Dir=use_global 7z_Delete_Temp=use_global Keymapper_Enabled=use_global Keymapper=use_global MultiGame_Enabled=use_global MultiGame_Background_Color=use_global MultiGame_Side_Padding=use_global MultiGame_Y_Offset=use_global MultiGame_Image_Adjust=use_global MultiGame_Font=use_global MultiGame_Text_1_Options=use_global MultiGame_Text_1_Text=use_global MultiGame_Text_2_Options=use_global MultiGame_Text_2_Offset=use_global MultiGame_Use_Sound=use_global MultiGame_Sound_Frequency=use_global MultiGame_Exit_Effect=use_global MultiGame_Selected_Effect=use_global MultiGame_Use_Game_Art=use_global MultiGame_Art_Folder=use_global [filters] parents_only=false themes_only=false wheels_only=false roms_only=false [themes] use_parent_vids=false use_parent_themes=false animate_out_default=false reload_backgrounds=true [wheel] alpha=.15 small_alpha=1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=360 norm_small=230 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=360 [video defaults] path=H:\hyperspin\Media\Super Nintendo Entertainment System\Video\ [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=false jump_timer=400 remove_info_wheel=true remove_info_text=true use_last_game=false last_game=Wario's Woods (E) random_game=false start_on_favorites=false [Special Art A] default=true active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [Special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [Special Art C] active=false x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active = true show_year = true show_manf = true show_description = true text_color1 = 0xFD070B text_color2 = 0xFD070B stroke_color = 0x000000 text_font = Style3 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640
thatman84 Posted July 10, 2018 Posted July 10, 2018 cool. So you have this core installed in retroarch and tested? parameters=cores/bsnes_mercury_performance_libretro_android.so Your games are in this format? romextension=sfc Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ChuckW Posted July 10, 2018 Author Posted July 10, 2018 Yes sir. I noticed that H: path was identical to a sample INI you posted a while back on another thread. Odd.
thatman84 Posted July 10, 2018 Posted July 10, 2018 H:/ only matters if you are using Hyperspin on a PC. Those lines are not supported on the Android version Check the links at the bottom of this Post. Everything regarding the .ini files is covered http://hyperspin-fe.com/forums/topic/28642-tutorial-hyperspin-android-overview-and-install/ Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
movd Posted July 10, 2018 Posted July 10, 2018 I have one suggestion that got me recently. Are your roms in zip format? If so, make sure you specify that. romextension=zip,sfc Edit: Sorry, I see that was already suggested.
ChuckW Posted July 11, 2018 Author Posted July 11, 2018 No, all of them are in SFC. I uninstalled and re-installed Retroarch, I tried both the Play Store version and 1.3.6 with no luck. I've determined only MAME, NES, Sega MS and Sega MD work. Everything else just launches, goes black for 2 seconds then goes back to the wheel. All of them will play if I launch them from Retroarch.
Honosuseri Posted July 11, 2018 Posted July 11, 2018 Not trying to be a back seat moderator but you shouldn't be linking to that site. I know you're trying to show the guide you followed but still, they give away Hyperspin content and games. You're breaking forum rules (just a friendly FYI) What you are describing sounds like you're trying to launch RetroArch, with a core that's not been installed. There are a lot of cores available in the online updater and it can be confusing. Ensure it's the bsnes Mercury performance core you installed as there is one called bsnes performance. "There is so much more and beckons me. To look through to these, infinite possibilities..."
thatman84 Posted July 11, 2018 Posted July 11, 2018 2 hours ago, Honosuseri said: Not trying to be a back seat moderator but you shouldn't be linking to that site. I know you're trying to show the guide you followed but still, they give away Hyperspin content and games. You're breaking forum rules (just a friendly FYI) Good catch I think that was added after I read it and reply. I have asked if the core is installed also...seems the likely cause. @kerflug let us know. Please post your whole SNES settings file or attach it to your next post Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Honosuseri Posted July 11, 2018 Posted July 11, 2018 Yeah saw your post, although the OP said he has that core installed I'm not convinced. I use snes9x but again that has several cores to choose from. The ini file has been posted and I can't see anything obviously wrong. Although I would suggest having roms only=true in the filters section. "There is so much more and beckons me. To look through to these, infinite possibilities..."
thatman84 Posted July 11, 2018 Posted July 11, 2018 Just to be sure go into Retroarch>Online Updater>Core Updater and download EVERY SNES core that is available Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
ChuckW Posted July 11, 2018 Author Posted July 11, 2018 Got it, I DEFINITElY didn't have that core, I had the SNES and SNES2010 installed. So I need to go and install all cores for all systems or is there a list of cores for each system that is preferred? Thanks to both of you for your patience and understanding!
thatman84 Posted July 11, 2018 Posted July 11, 2018 2 minutes ago, kerflug said: Got it, I DEFINITElY didn't have that core, I had the SNES and SNES2010 installed. So I need to go and install all cores for all systems or is there a list of cores for each system that is preferred? Thanks to both of you for your patience and understanding! No worries, that question is open to many opinions. It’s a case of just researching and finding out. For SNES there’s many people that stick to snes9x. personally I download ALL cores. Most are small but the MAME ones are pretty hefty on storage. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Honosuseri Posted July 12, 2018 Posted July 12, 2018 I personally wouldn't download them all, partly because some cores are rubbish. For example to do the amstrad cpc you must use caprice, the croco core is useless. RetroArch isn't always the way to go, some dedicated emulators are better. I don't use RA for the N64, Nintendo DS, Dreamcast and Amiga for example. Although more often than not I am using RA, as I have set a quit key which is useful. Cores also have a habit of disappearing from the build bot. I remember a mame core vanishing which we needed to do Cave arcade games, was quite sometime before it returned. So... Either do as thatman suggested and install them all or if you see a system you think you might emulate down the road, install the core. "There is so much more and beckons me. To look through to these, infinite possibilities..."
