Commodore Amiga up and running
For those of you who want to run Amiga games under hyperspin:
Need:
1: Whdload amiga games.
2: Winuae loader version 1.73 (http://headsoftware.net/index.php?category=winuaeloader)
3: WinUAE version 2.3
Use Hyperlaunch
Settings:
[exe info]
path=C:\Hyperspin\emulators\Amiga\
rompath=C:\Hyperspin\emulators\Amiga\games\
userompath=false
exe=WinUAELoader.exe
romextension=zip
parameters=
searchsubfolders=
pcgame=false
winstate=HIDDEN
hyperlaunch=true
Add this to the hyperlaunch script:
;**********************************AMIGA***********************************
else if (systemName = "AMIGA" && executable = "WINUAELOADER.EXE")
hideDesktop()
Hotkey, %exitEmulatorKey%, CloseProcess
Run, %executable% -mode whdload -rom "%romPath%%romName%%romExtension%", %emuPath%, UseErrorLevel
process, WaitClose, winuaeloader.exe
Change the paths and names to what your setup requires.
Under winuaeloader remap keyboards a and b to your joysticks.
Port 0 should be keyboard B and port 1 should be keyboard A.
You now have the commodore Amiga up and running.
Now who's making the video snaps. :top:
  • 6 months later...
I have a problem getting this to work in hyperspin but it may also be an issue i have with the loader ,after getting the loader working and loading up roms i couldn't get filters or a good fullscreen setup so i changed the emulator/loader cfg to enable filters and fullscreen stretch but after saving the cfg i load up a game via the loader and i seem to be getting the emulator window opening up and then when i click run via emulator the rom loads as expected wih filter and stretch.
If i try to load up via hyperspin all i get is the loader window ,any help would be great
thanks.
I will check my system and see if I made any changes. I believe I setup the loader for fullscreen and other features outside of Hyperspin. Once the settings were saved It ran fine under Hyperspin.
Need:
Use Hyperlaunch
Settings:
[exe info]
userompath=false
romextension=zip
parameters=
searchsubfolders=
pcgame=false
winstate=HIDDEN
hyperlaunch=true
hideDesktop()
What software do people use to create flv files?
Just to add to this thread. I use winuaeloader and the following bat file which I name "amigalaunch.bat" in the same folder as winuaeloader. I call this bat file from hyperspin.
"amigalaunch.bat" contains:
winuaeloader -whdload -game %1
The "%1" is the parameter passed to it, which is the path and rom name passed to it from hyperspin.
A simple solution, but it works well for me. Hope it helps someone.
  • 3 months later...
  • 3 weeks later...
Need:
Use Hyperlaunch
Settings:
[exe info]
userompath=false
romextension=zip
parameters=
searchsubfolders=
pcgame=false
winstate=HIDDEN
hyperlaunch=true
hideDesktop()
I set this up, and it tried to load the game, then says game.slave not found, up in the top of the amiga game screen. On every game I try. Any ideas?
And the Game.slave is the name of the game I am trying to play, like North&South.slave or Turbo.slave ect..
Corrections, My Roms were Double Zipped, Weird.. But the game starts to load, then says Kickstart rom cannot be read. And I have all the Kickstart roms. :(
Any Ideas?
  • 2 years later...
hideDesktop()
How do I use this "hyperlaunch script"?
Sorry, still a bit new to HyperSpin. :)
Are you using RocketLauncher and HyperLaunchHQ? They have their own new scripts. This is a very old thread.
Thanks,
Ron
I am indeed using RocketLauncher and HyperLaunchHQ.
When running an Amiga gane through HyperSpin it seems to start HyperLaunch but nothing appears on the screen, WinUAE or WinUAE Loader never appears.
The process for HyperLaunch stays minimized in the system tray and I can't launch another game before I terminate it manually.
Same thing occurs when trying to run an Amiga game through HyperLaunch HQ.
However running it straight through WinUAE Loader it runs the games just fines.
I'm currently testing it with the WHDload rom of Cannon Fodder as I know that loads flawlessly in WinUAE.
Anyone else had this issue or know how fix it. I'd love to get Amiga running in HyperSpin.
EDIT:
Here's some info on the folder structure.
WinUAE and WinUAE Loader in:
"H:\Hyperspin\Emulators\Commodore Amiga\WinUAE"
Kickstart roms in:
Amiga game roms in:
"H:\Hyperspin\Games\Commodore Amiga"
Amiga settings (from "Commodore Amiga.ini"):
[exe info]
path=H:\Hyperspin\Emulators\Commodore Amiga\WinUAE\
rompath=H:\Hyperspin\Games\Commodore Amiga\
userompath=
romextension=zip
parameters=
searchsubfolders=
pcgame=false
winstate=HIDDEN
hyperlaunch=true
HyperLaunch Amiga settings (from "Emulators.ini"):
[ROMS]
Default_Emulator=WinUAE Loader
Rom_Path=..\Games\Commodore Amiga
HyperLaunch WinUAE Loader settings (from "Global Emulators.ini"):
[WinUAE Loader]
Emu_Path=..\Emulators\Commodore Amiga\WinUAE\WinUAELoader.exe
Rom_Extension=zip|info
Module=WinUAE Loader.ahk
HyperPause_Save_State_Keys=
HyperPause_Load_State_Keys=
EDIT 2:
Well that's just nuts.
It works perfectly now after deleting the "HyperLaunch.log" inside the HyperLaunch folder.
I do not think this is 100% what fixed it, but it is the only thing I did.
I'll return if it occurs again OR if I found out what really fixed it so others who have the same issue will be able to fix it! Yay :wavey:
