connorsdad Posted May 19, 2014 Posted May 19, 2014 As per the title, how are you guys implementing a night mode switch? Software or hardware? Sent from my SM-N9005 using Tapatalk
maxxsinner Posted May 19, 2014 Posted May 19, 2014 I believe there was a software way of doing this although I cannot seem to find the page? All it was doing was swapping the LEDwiz config out with another config file with zeros in the places for the noisy feedback devices. Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
arngrim Posted May 19, 2014 Posted May 19, 2014 when you generate files from configtool, it creates ini and nofeedback ini files, and these ones disable contactors, knocker etc that was working with hyperpin, ledcontrol.ini files and fplaunch wip10, but since dof ini changed their names to directouptutconfig.ini it doesn't work anymore. we need a new way to switch from normal to nofeedback files, with pinballx or hyperpin
connorsdad Posted May 19, 2014 Author Posted May 19, 2014 Couldn't I just put a switch in between the power source and zebs virtual output kit board? Sent from my SM-N9005 using Tapatalk
Spektre99 Posted May 19, 2014 Posted May 19, 2014 connorsdad said: Couldn't I just put a switch in between the power source and zebs virtual output kit board?Sent from my SM-N9005 using Tapatalk Could work, but that is probably not the best solution. It would be better to cut the power prior to the power supply powering Zeb's board, but still not great. I'd vote with Max and Arngrim's idea of separate DOF files.
connorsdad Posted May 19, 2014 Author Posted May 19, 2014 Spektre99 said: Could work, but that is probably not the best solution. It would be better to cut the power prior to the power supply powering Zeb's board, but still not great.I'd vote with Max and Arngrim's idea of separate DOF files. That's what meant Sent from my SM-N9005 using Tapatalk
