AutoKustomWheels v1.0
skarstoker
AUTO KUSTOM BETA 2 :bandit:
The wait is finally bears fruit :top:
DOWNLOAD
This is only a beta of what will be the final version ...
It is written in Visual Basic 2010, using WPF
In the section on "Wheel" is 99.9% complete and functional, just missing the Language selector
In the second section called "3D" is in development, can be used but not
have the option to save, at least in this beta, if we take a percentage, this is
is 60% complete ...
That has not been completed yet?
I tell you, visual basic, is a basic programming, by this point, I have
many limitations to the programming, besides not having some errors
more complex tasks, without forgetting that a 3D object is not quite right, without
using "shaders" and other effects, such as "bump map" cuvemaps, among others,
Also carry out the designs in 3D boxes and cartridges, etc ... is no easy task
less when first learning to use 3D design software ...
Status:
I will be a time away from my project, but everything is for the sake of it ...
I am currently learning 3dsMax and SketchUp (3D design to manufacture), and bought
the book: "The Bible of C#" which I'm reading. Learning is something that is needed
much time, patience and effort, not to mention the perseverance ... And when I feel
thoroughly familiar with this language, try to learn about XNA in order to
effects using Shader ... and to represent 3D designs with more definition, and
transfer all Visual Basic code to C # ...
If you find a solution to this, which is faster, I assure you I will tell ... by
now I can only learn ....
A distance hug to my good friend Koolbrez67, thanks to the work of
graph and its motivation, has completed the first chapter of this program ...
No more to say
Stoker Skar says goodbye[/b]
*************************** OLD VERSION ************************************
hello friends, do not speak very good English but I try.
I made this program to facilitate the transfer of a normal wheel to a kustom wheel ... I hope you like it
not forgetting our friend koolbrez67 credits, thanks to their inspiration and working hours, we know the kustom wheels, with the advantage that now will save you many hours of work, devoting more time to perfect other aspects.
Auto Kustom Wheel's
how to use
1 .- Choose the background (FONDO)
2 .- Select the directory of the normal wheels (WHEELS)
3 .- Select gloss (Optional: if you want the image does not have this effect,
nogloss.png selects located within resources)
4 .- Choose Save (GUARDAR)
The files are saved to where you unpacked the program in a folder called Kustom
Well no more words and unloading:
DESCARGAR AUTOKUSTOMWHEELS V1.1
VERSION NOTE:
version 1.0 (RELEASED)
Released
Version 1.1 (RELEASED)
Added option of gloss
Version 1.2 (NOT RELEASED)
A new partner joins the team, known as koolbrez67
Fixed the Bug off from its wheel.
Fixed the bug that some wheel did not look.
Fixed bug that some wheel to take the white transparent.
English language was added in the controls
NOTE: dig out that both the gloss and the background should be the same size and match each
Ask anything in this thread ...
PS: If you want to post on other sites, no problem, just respect the copyright ...
EDIT: have already found bugs or bug
working on it
here are those version
AutoKustomWheel v1.1
AutoKustomWheel v1.3
AutoKustomWheel Beta 2
Creator of
AutoKustomWheels
  • Replies 98
It's a nice combiner but It would be cool if you could add one more layer that is the gloss layer. They look plain without it.
Choose a background
Select the Normal wheels
Select a gloss layer
Then save.
Background
Combined With Normal wheel art
Gloss Overlay
Combined with Back ground and Wheel art.
Having the third option for gloss can make a huge difference.
I would be happy to test and add art work templates so your program can do all of the different Kustom wheel art.
Koolbrez67
Hey man, this program rocks !!
Thanks a lot, I actually have to make my own custom wheels, using jeepguy81 template.
I can use your program, but it needs to add at least two layers : one for the background (each wheel image has a different bg color) and one for the manufacturer logo.
Here is a samle of them :
"Dindon" means "Turkey" in french.
have if I understood well:
want to add another layer to add a manufacturer's logo
the game, no problem it would have to modify the program and
Next add a background layer after and before the wheel, on the other
side ...
for having a different color background background, you should
separate your wheel, by company, for the moment at hand, or to create a
program that performs it, not a bad idea, but that it will not last
promise much, due to my lack of time
EDIT:
talking to koolbrez67
it is better to leave the program as simple ...
On the other hand, what you can do is be ready the background with the logo, and separated for the moment at hand, according to the different wheel companies
Creator of
AutoKustomWheels
I can't seem to find Kool's templates since the FTP was re-organized. Any help? I'd like to try to add some but get as many borders and backgrounds as possible so I can ensure my new ones are identical.
Thanks
Testing out program issues that I've found with it so far.
It doesn't like wheel art that has white in it.
Same with the gloss i have to make it darker for it to take other wise it cuts it out.
I changed my template to use the full 400w x 175h.
The wheel images need to be resized so there a little bigger. when there being combined together. What size are you having the resized to?
I've been working with Skarstoker on fixing the bugs. It has been coming along nicely. AutoKustomWheels program will making kustom wheels so easy and has so many options. I'm going to make a video when we are finished on how to use the program and show you how fast this program works. So stay tuned Hyperspinners.
Hey dudes, will the quality of the resize will be as good as PSP or PS (bicubic or something) ?
according to schedule should be, the highest resolution allowed by the program Hyperspin for wheels without losing quality
pictureGraphic.InterpolationMode = System.Drawing.Drawing2D.InterpolationMode.HighQualityBicubic;
Creator of
AutoKustomWheels
If you can make your program make these kind of wheel images then that would be super sick. I would definitely like to try it out if it does.
hi, thanks for the recommendations
at this time and I am adding these new options hopefully you enjoy them
do we wanna include the dev/manufacturer logos as well. It was just convenient for me to place it in the wheel instead of on the vert themes i'm doing
hi, thanks for help
I'm working on it, it's really difficult to make a flexible program that suits many changes, but not impossible ...
: D
Creator of
AutoKustomWheels
Let me know if you run into issues writing this software to be very versatile, I can whip the same thing up in a couple weeks that would be extremely customizable since I like the idea. Dont wanna step on any toes so I'll let you have at it. I have a bunch of ideas that could make this kind of thing pretty sweet. Nice work so far, don't give up, thanks!
Dudes, your software seems to rock !
Congrats !
PS : If I understand well, the manufacturer logo option will allow to add automatically, using mame.xml, manufacturer logos layer for each wheel image ?
Congrats !
Yes, if the program reads the same XML file, which occupies Hyperspin, where
extracts the name of the manufacturer, in addition to apply filters to characters
strange to have no problem with their names.
On the other hand ...
add an option that displays the name of the logos, which are not in
Directory logos, this makes it easy to add logos a little easier.
The size of the logos of the manufacturer, is something we should discuss ...
to have a standard size
logos need to test this part, I have random pictures with the manufacturer's name and it works.
Looks awesome, will there be an English language release?
of course, and in turn can translate into many languages but, because it makes use of a file "Lang.ini" editable
Awesome Work !!!
thank you very much :D
Great Job guys, but I must second the English release :)
I'm working as quickly as possible to the release of version 1.3
Atte
Skar Stoker
Creator of
AutoKustomWheels
