Please advise on system spec
connorsdad
In my grounds 4 divorce cab I have the following spec:
Intel i3-2100 sandybridge
Nvidia GeForce GTX 660 Ti
8 gb ram
It plays pretty much everything fine but it struggles with some future pinball tables such as stern tron and 3 angels, I would like to play everything flawlessly in my vpin cab, including unit3d pinball. I can't seem to find a recommended spec for fp or unit3d pinball, what would you guys recommend for my vpin cabinet build?
Hoping to nip into www.overclockers.co.uk this weekend to pick something up.
Thanks
sig2.png?raw=1sig.jpg?raw=1
You will need a fair bit on Unit3D, those pixel lighting kills it for me when you go to cabinet view. Desktop view isn't no way near as bad with lots of settings wacked up.
I think i5 should just about do that (but have heard troubles), FP it will piss through. I never buy intel, that's because I've never needed too, I always get by with AMD cpus. I'm not recommending against intel it though. If you got the money go for an i7 and then you won't have to worry for a good while.
BUY CHEAP BUY TWICE, BUY WEAK BUY TWICE.
DAMN - Nice Link!!!
I'm using an I5 @ 3.4ghz with 8gb DDR3 (WinXP only sees ~ 3.5) and a 480GTX (1.5gb)
I would say it can handle almost anything - My only exception is when I run Avatar and the B2S, I get an out of memory error.
Without the B2S, it's fine. Every other B2S out there (with table) is fine.
Guess what I'm saying is: If you have overkill now, in couple years, it'll be just a "good" setup.
If you can afford it - go for it :-)
STAY AWAY FROM SLI - From what I've read, NOBODY has seen any benefits from SLI on VP.
I believe every I5 / I7 motherboard with support SLI - just don't use it for SLI.
I was under the impression I had to use sli/crossfire to run 2 cards. The last time I was up to date with computer specs a pentium III was king lol.
Sent from my SM-N9005 using Tapatalk
That video card and amount of ram should be more than enough. I would say your cpu is under powered. If you can afford a quad core i7 w/hyperthreading, you should be future proof for a while. That is what I just put in the cab I just built and I haven't found anything I can't run yet, of the normal arcade/pinball type stuff.
So basically any motherboard that supports 2 gfx cards, i7 chip and 8 gb ram will do just fine?
Got me some goodies :)
Samsung 250gb SSD http://www.overclockers.co.uk/showproduct.php?prodid=HD-168-SA
(Overclockers)
Corsair 600W PSU http://www.overclockers.co.uk/showproduct.php?prodid=CA-048-CS&groupid=701&catid=123
(Overclockers)
Gigabyte Z97P-D3 Intel Z97 http://www.overclockers.co.uk/showproduct.php?prodid=MB-498-GI&groupid=701&catid=5
(Overclockers)
Intel Core i7-4770K 3.50Ghz (Haswell) http://www.overclockers.co.uk/showproduct.php?prodid=CP-471-IN
(Overclockers)
Corsair 8GB DDR3 http://www.overclockers.co.uk/showproduct.php?prodid=MY-371-CS&groupid=701&catid=8
(Overclockers)
I'll use my 2 existing cards, GTX 560 and a GTX 650.
Nice buys! I am in the process of putting together a new personal machine and am looking at the Gigabyte line as well - Z97X-Gaming5. I think you should have no issues playing anything with those specs!
Got both fp and vp setup in pinballx, tables such as 3 Angels and stern Tron play perfectly at maximum settings, no drop in fps at all :)
