How-To nullDc FXAA
boomerps2
Is there anyway to get nullDc to support any kind of FXAA? If so, how did you go about doing that? I've tried enabling FXAA through Nvidia Control Panel but doesn't work. All the fighting games sprites look horrible. Thanks in advance.
Have tried Sweetfx?
I've just tried it with DC while writing this, It didn't seem to make much difference. Maybe it would work with Demul?
I would not add anything to Demul that would tax the gpu anymore ridiculously than it already does.
I am......Machine
Have tried Sweetfx?
What was the possess to enable this?
You just place the files in the Demul directory, open the SweetFX_settings.txt and switch on the settings you want (changing "0" to "1"), then each setting can be adjusted, if required to suit what you want.
Be aware I haven't tried it (I've only got it working with Playstation emulators)and like Trnzaddict says, it may have a big performance hit if it works at all.
You can just delete the files you placed in the Demul folder as nothing is modified.
It looks like FSAA is on by default.
