Kevinv10 Posted August 7, 2018 Posted August 7, 2018 Hi, i’m looking for the past 2 weeks a solutions on the hyperspin forum but don’t find anything that helps. The problem is if i startup Hyperspin the arcade buttons don’t respond. It only responds when i first click a button on the keyboard.When i get to the second wheel. The problem repeats itself. So back again, click on keyboard then the arcade joystick responds. I don’t know what the problem is. I did everything what was said on the tutorial . Can anyone help me please ? I know that its the 10000000 time that someone ask for help with the controls. But i’m really hopeless now. I can’t figure it out. Help is welcome. Kevin
rapidformz561x Posted August 10, 2018 Posted August 10, 2018 hi kevin im having the same problem aswell you need to look in the log.txt file and you will see the boot sequence i keep getting an error saying parameters arent set and thats where i get pissed lol
Creezz67 Posted August 10, 2018 Posted August 10, 2018 Use the Hyperspin script, just search for it on here Much better than Joy2Key
ninja2bceen Posted August 10, 2018 Posted August 10, 2018 Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Kevinv10 Posted August 11, 2018 Author Posted August 11, 2018 I have tried the Hyperspin script. The joystick and the buttons work. But when i do nothing, the wheel spins and randomly selects menus. This is really frustrating. I also tried to setup another profile with Joytokey with my 8bitdo controller. With the 8bitdo controller works everything perfect. So maybe the problem is just the zero delay usb encoder. What can i do about it ?The zero delay usb controller has no problem with playing games. But only if i set the controls up in the emulators.Not with Joytokey.
Kevinv10 Posted August 11, 2018 Author Posted August 11, 2018 On 8/10/2018 at 12:34 AM, rapidformz561x said: hi kevin im having the same problem aswell you need to look in the log.txt file and you will see the boot sequence i keep getting an error saying parameters arent set and thats where i get pissed lol Expand hi, i have looked to the log and i think i get the same as you. 01:32:04 PM | HyperSpin Started 01:32:04 PM | Going FullScreen 01:32:04 PM | Checking for updates 01:32:04 PM | Update Check Complete 01:32:04 PM | Startup program: JoyToKey.exe 01:32:04 PM | Startup params not set 01:32:04 PM | Working directory: C:\RocketLauncher\ 01:32:04 PM | Window State: NORMAL 01:32:04 PM | Launching JoyToKey.exe 01:32:04 PM | Command Line is JoyToKey.exe 01:32:04 PM | Playing intro video 01:32:10 PM | Error intializing joysticks 01:32:10 PM | Menu Mode is multi 01:32:10 PM | Loading Main Menu.xml 01:32:11 PM | Main Menu.xml successfully loaded 01:32:11 PM | Main Menu wheel loaded successfully 01:32:40 PM | Loading Nintendo Game & Watch.xml 01:32:40 PM | Main Menu.xml successfully loaded 01:32:41 PM | Nintendo Game & Watch wheel loaded successfully 01:32:43 PM | Loading Main Menu.xml 01:32:43 PM | Main Menu.xml successfully loaded 01:32:44 PM | Main Menu wheel loaded successfully 01:32:48 PM | Exit program unavailable 01:32:48 PM | Quiting Hyperspin 01:32:49 PM | Bye! I have tried 1000 things and i found out if i don't set the buttons up in Joytokey and i setup only the joystick. I can navigate in Hyperspin without any problem. When i give an assignment to a button. I have all my problems back. So the problem is something with the buttons but i only can't figure it out .
Spawk Posted August 12, 2018 Posted August 12, 2018 On 8/11/2018 at 11:07 AM, Kevinv10 said: I have tried the Hyperspin script. The joystick and the buttons work. But when i do nothing, the wheel spins and randomly selects menus. This is really frustrating.Is this not just attract mode kicking in? Check the "Attract" tab in HQ. You can increase the time it takes to kick in (or even disable it). On 8/11/2018 at 11:07 AM, Kevinv10 said: I also tried to setup another profile with Joytokey with my 8bitdo controller. With the 8bitdo controller works everything perfect. So maybe the problem is just the zero delay usb encoder. What can i do about it ?The zero delay usb controller has no problem with playing games. But only if i set the controls up in the emulators.Not with Joytokey.The last couple of sentences dont make sense to me, you should always set in game controls in the emulators themselves. JTK should only be used to navigate HS and exit emulators. Maybe handle save states or things the emulator generally doesnt let you assign a button for.Sent from my SM-A520W using Tapatalk
Kevinv10 Posted August 12, 2018 Author Posted August 12, 2018 On 8/12/2018 at 7:03 AM, Spawk said: Is this not just attract mode kicking in? Check the "Attract" tab in HQ. You can increase the time it takes to kick in (or even disable it). The last couple of sentences dont make sense to me, you should always set in game controls in the emulators themselves. JTK should only be used to navigate HS and exit emulators. Maybe handle save states or things the emulator generally doesnt let you assign a button for. Sent from my SM-A520W using Tapatalk Expand I disabled it. The wheel stopped spinning. But it still selects menus when i don't do anything. It even exit Hyperspin without touching anything.
ninja2bceen Posted August 14, 2018 Posted August 14, 2018 Did you buy a preconfigured drive by chance?Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Kevinv10 Posted August 15, 2018 Author Posted August 15, 2018 On 8/14/2018 at 10:30 PM, ninja2bceen said: Did you buy a preconfigured drive by chance? Sent from my iPhone using Tapatalk Expand No, i just downloaded HyperSpin here on the website en set it up like on the tutorials.
