MimoPakou Posted October 30, 2018 Posted October 30, 2018 I have setup hyperspin correctly (I think) I have added some nes roms.When I launch them from rocketlauncher it works fine but when I go into hyperspin and I press the nes system it will kick me back to the main menu without showing me even the roms.Btw hypersync says: Hypersync could not find any configured systems. Thanks in Advance.
Spawk Posted October 30, 2018 Posted October 30, 2018 Sounds like you are not connected to RL properly. Check here: And these 2 spots in RL: and:
adamg Posted October 30, 2018 Posted October 30, 2018 Definitely check the RL settings but it also sounds like you might have artwork issues.
Spawk Posted October 30, 2018 Posted October 30, 2018 If you are using a filter in HQ such as "Roms Only", not having the Rom Path and extensions set can cause this behavior as well. * notice that you do NOT set executable path here. Settings here are just used to populate the wheel.
volumetric Posted October 30, 2018 Posted October 30, 2018 Definitely not RL. He's not getting to the point where RL would be called. Much more likely a hyperhq filter issue.
Spawk Posted October 30, 2018 Posted October 30, 2018 2 minutes ago, volumetric said: Definitely not RL. He's not getting to the point where RL would be called. Much more likely a hyperhq filter issue. This is what lead me to believe my 1st pic: settings.ini was most likely as well... Filters can cause exact same symptom as well though.
MimoPakou Posted October 31, 2018 Author Posted October 31, 2018 Thanks.It was the roms only filter there is something buggy about it
