mikty Posted February 10, 2019 Posted February 10, 2019 Hi, with the recent progress of neo geo cd emulation on retroarch fb alpha witch launch bin cue and ccd format, is someone is able to launch it from hyperspin android ? on the stand alone retroarch, we have to launch a game using a sub menu so for our hyperspin setting, it would be tricky. If someone a success with this thanks regards
thatman84 Posted February 10, 2019 Posted February 10, 2019 Not tried myself yet. My dabble soon, been working on my AES/MVS setup and currently have Neo CD with CHD on mame. I only found a set of 44 bin/cues so wont go all out until I finish collecting Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
mikty Posted February 11, 2019 Author Posted February 11, 2019 Ok thanks. I would like to use Fba for the runahead feature.we have to wait from retroarch team to launch directly cue from menu thanks
thatman84 Posted February 11, 2019 Posted February 11, 2019 4 hours ago, mikty said: Ok thanks. I would like to use Fba for the runahead feature.we have to wait from retroarch team to launch directly cue from menu thanks Subsystem is a commanline option "--subsytem" is what you want Although I am uncertain thst we can do this with Hyperspin. I would sugest adding --subsytem neocd to the end of the parameters line in the ini. I would have to do a log from Hyperspin on my shield to refresh myself on the Libretro intent. I think it may cut any additions off. In this case its another limitation to Hyperspin android......and with no word on anymore support negatives are racking up with the ommisson of arch64 aswell now Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
mikty Posted February 11, 2019 Author Posted February 11, 2019 Thanks I will try this. And for aarch64 support hope someday reznate could look after is baby!
thatman84 Posted February 11, 2019 Posted February 11, 2019 @mikty I gave this some testing tonight, It sort of came back to me now...... Afaik Hyperspin Andorid settings files dont expose use the correct placement of additions make the extra --subsystem neocd command work. We have a rompath= Must be a file path to the roms exe= Must be an apps packed name otherwise Hyperspin throws an error of Missing Emulator parameter= Basically to only area to attempt edits The way Hyperspin is preconfigured with the retroarch launch intent means IMO it wont be possible. I could be wrong but I am fairly certain, Same with the CONFIGFILE path, its preconfigured.. Here are the log exerts if you try to edit the parameter line 02-11 20:30:32.697 31765 31783 I RetroArch: [ENV]: libretro path: [/data/data/co m.retroarch/cores/fba_libretro_android.so --subsystem neocd] 02-11 20:30:33.019 31765 31783 W RetroArch: --libretro argument "/data/data/com. retroarch/cores/fba_libretro_android.so --subsystem neocd" is neither a file nor directory. Ignoring. 02-11 21:38:27.985 19478 19500 I RetroArch: [ENV]: libretro path: [/data/data/co m.retroarch/--subsystem neocd cores/fba_libretro_android.so] 02-11 21:38:28.303 19478 19500 W RetroArch: --libretro argument "/data/data/com. retroarch/--subsystem neocd cores/fba_libretro_android.so" is neither a file nor directory. Ignoring. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
mikty Posted February 12, 2019 Author Posted February 12, 2019 thanks for your try, I have follow your advice and like you, can't launch these. what a pity thanks again
thatman84 Posted September 22, 2019 Posted September 22, 2019 @mikty I remembered you wanted to use FBNeo for NeoCD it should be possible now (as soon as this core builds again) not tested myself just got the email. https://github.com/libretro/FBNeo/pull/159 Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
mikty Posted September 22, 2019 Author Posted September 22, 2019 Yes thanks I see this but I don't know how to configure this, I update the core but can't see any option about it. I made a per content folder override save but still need subsystem Thanks again for your attention regards Edit: I think the buildbot isn't update so need to wait tomorow thanks
thatman84 Posted September 22, 2019 Posted September 22, 2019 Yeah it will need a while to be live i guess. The last android build was 12hrs ago Souds like you games need to be in a neocd folder Roms/neocd/-yourgames- for example. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
mikty Posted September 22, 2019 Author Posted September 22, 2019 Yes thanks all my iso and chd are on a NAS synology but I manage to configure right paths for others cd cores support with hypesrpin android on shield tv Hope it will works and maybe in the future the chd support. I wait for month the neocd specific core whitch support chd but isn't available for android yet (only windows and not by the core updater) Thanks
mikty Posted September 23, 2019 Author Posted September 23, 2019 so thanks again for your reminder. it works like a charm with the last core update from hyperspin shield tv even from isos stored on a nas synology. the heaven would be the chd support but doesn't seem to be a priority for the core developper unfortunely regards
thatman84 Posted September 23, 2019 Posted September 23, 2019 2 hours ago, mikty said: so thanks again for your reminder. it works like a charm with the last core update from hyperspin shield tv even from isos stored on a nas synology. the heaven would be the chd support but doesn't seem to be a priority for the core developper unfortunely regards Yeah he flat out refused to add it himself (understandable reasons imo) so you can only hope someone else turns up with a pull request to add it in. Glad it’s working for you Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
mikty Posted September 23, 2019 Author Posted September 23, 2019 Thanks. The only problem is the run ahead feature witch is less good as regular neogeo aes and mvs. I have some audiocrackling and must activate the 2nd instance and and lower the frame number. Strange because its the same core fbneo.
