Using real quarters with mame - Tankstick
thenoob
Hey everyone
i just noticed the red and black wired out of the tankstick I have are ran to the coin door.  Is there a way to test functionality inside mame or an option to turn on coin enable of some sort with the tankstick/mame?
That button assignment in MAME is normally 5 on the keyboard. Assuming the wires run to the coin switch in the coin door, all you'd need to do is pull up the in-game menu and check what the Player 1 Coin key is set to. If it's not already the coin switch, just hit Enter on the keyboard and trip the coin switch once and that should set it.
The cab of a friend has a fastASD, the wire dedicated to the coin is attached to coin button AND the real coin slot.
You need to check coin slot, usually for home cabs they are "free drop", they accept any coin. The coin mask, anyway, may not accept all coin.
