gunit Posted July 3, 2019 Posted July 3, 2019 Evening I'm currently running (Mame 0.162 - split+chd) - all seems good but should I upgrade ? I seem to recall it being hard to get cleaned up when I did it 3 years ago but my memory is terrible. What do you think of 0.162 ? Should I upgrade ? What is the best Version ? Cheers
griffin518 Posted July 3, 2019 Posted July 3, 2019 Best version is always the latest version. Yes, you should update. There have been a ton of bug fixes since then.. if you go for it, you might consider the non-merged set if you use any clones. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
gunit Posted July 3, 2019 Author Posted July 3, 2019 Is it an easy upgrade ? feel like a complete noob again :(. Would I need to source a complete new Rom set ? not even sure why I labeled it (Split + chd) ? must of been important hahahaha
griffin518 Posted July 3, 2019 Posted July 3, 2019 Yes, it's pretty easy... just take your time with it. Worst part is re-mapping buttons and setting up shaders again (if you use them). You should generally have the romset which matches the version, yes. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
thatman84 Posted July 3, 2019 Posted July 3, 2019 I would not say it’s easy. generally best to grab a whole new set. Split+chd is usually advised. Non merged also possible but takes up more space. its matching artwork and videos that can be tricky. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted July 3, 2019 Posted July 3, 2019 1 minute ago, griffin518 said: Worst part is re-mapping buttons and setting up shaders again (if you use them). And this Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
gunit Posted July 3, 2019 Author Posted July 3, 2019 Not done Shaders and buttons yet :). Partly why i'm thinking of upgrading for the improved HLSL. Would you kindly point me to the latest Split + chd mame version ? The emulator not roms
shitoken Posted July 4, 2019 Posted July 4, 2019 Why do you need to remap the buttons and set the shaders again if is already in config + using ipac?
griffin518 Posted July 5, 2019 Posted July 5, 2019 On 7/3/2019 at 2:26 PM, thatman84 said: I would not say it’s easy. generally best to grab a whole new set. Split+chd is usually advised. Non merged also possible but takes up more space. its matching artwork and videos that can be tricky. I'd say it's one of the easier updates you can do... excluding time to download a new romset, it usually takes me about 10 minutes. You do make a good point about artwork and videos (and themes!) though. I user HyperSpin Checker to confirm I'm not missing anything. On 7/4/2019 at 2:04 AM, shitoken said: Why do you need to remap the buttons and set the shaders again if is already in config + using ipac? MAME's config format changes slightly from version to version... since 0.162 there have been a bunch of changes. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
