Joenaz Posted January 13, 2020 Posted January 13, 2020 Hey all, banging my head on this.... all of a sudden, When I launch hyperspin it skips the intro and launches right into the systems wheel. All my controls are unresponsive too. Checked RL path, looks good.... all AV disabled... HL, HyperHQ, RL,RLUI,HS startup script all set to admin. Even tried without being set to admin... looking for any direction on what I might have missed. Craziest thing it happened after a reboot. I was using it just fine, rebooted, problem now! Thanks for any insight you all have.
thatman84 Posted January 13, 2020 Posted January 13, 2020 Sounds like an input issue. Is it possible a Stuck key is causing it? Not sure how your controls are configured. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
adamg Posted January 14, 2020 Posted January 14, 2020 It is almost certainly an input issue. First unplug whatever keyboard/encoder you are using and launch HyperSpin. Does it do the same thing? If so, this is probably a software issue. I would guess you have vjoy installed but that is a shot in the dark. I say that because I had that issue in the past and vjoy was the culprit. If not, then you have an issue with your input device. Open notepad and then plug in your input device. This may allow you to see what key is being pressed. if it is Ctrl, Alt, or Shift you can check those in On-screen Keyboard.
FETTABUBA Posted February 5, 2020 Posted February 5, 2020 Hi Did you get this sorted, I’m having the same issue, So before I go ahead changing config sand defaults in my boards what worked for you?? Ian
