BlueMegaman Posted February 7, 2020 Posted February 7, 2020 Hi, for some reason mame roms aren't loading through Rocket Launcher UI. Emulator loads fine outside of Rocket Launcher, and loads fine through rocket launcher. But when I audit games and try to load a game through rocket launcher it doesn't boot up. Games run fine through mame emulator. It's only through rocket launcher they don't load. And games don't show up in Hyperspin app. I get this error message waiting for ahk_Class MAME
Creezz67 Posted February 7, 2020 Posted February 7, 2020 set skip checks in RL to rom only and see if that helps.
BlueMegaman Posted February 8, 2020 Author Posted February 8, 2020 That didn't work. Im using the latest groovy mame on my CRT. I don't know if this is causing the issue.
Creezz67 Posted February 8, 2020 Posted February 8, 2020 I don't use Groovy MAME, use normal MAME64 OR MAME Arcade and see if that works.
BlueMegaman Posted February 8, 2020 Author Posted February 8, 2020 Does normal mame support 15khz? I use Groovy Mame for greater emphasis on CRT support.
BlueMegaman Posted February 8, 2020 Author Posted February 8, 2020 I tried with regular mame just to see if it works and it doesn't. Regular mame and groovy mame doesn't work.
gigapig Posted February 9, 2020 Posted February 9, 2020 On 2/8/2020 at 11:53 PM, BlueMegaman said: I tried with regular mame just to see if it works and it doesn't. Regular mame and groovy mame doesn't work. Expand Have you updated the mame module recently? http://www.rlauncher.com/forum/showthread.php?6201-MAME-v0-212-don-t-launch-with-RocketLauncher&p=44551&viewfull=1#post44551
shitoken Posted February 10, 2020 Posted February 10, 2020 I was having same problem after uodating my MAME to latest vr. You need to use the latest module as giga provided aboveTapatalk を使用して私の MIX から送信
BlueMegaman Posted February 13, 2020 Author Posted February 13, 2020 That worked. Games now load through rocket launcher UI. I have a new problem, now mame roms don't show up in HyperSpin. All my other systems do but mame is the only one that doesn't. I set the rom path to match mame roms folder in HyperSpin HQ and it doesn't show. I also set the sxtensiuons to zip files.
crashdogy Posted March 10, 2020 Posted March 10, 2020 hello , same kind of issue only with some of the games like Indian Jones and the temple of doom Mame loads wrong bios how can i fix this and make it load the right one ?, are51 also not working in Hyperspin but in Mame its runs fine fixed Indian Jones and the temple of doom and marble madness by running in Mame selecting bios i wanted and saving machine config are51 , mach 3, carnevil, maximum force kind of load but then crash back to Hyperspin they work fine in mame.
