ReDream on hyperspin
whatnottodoingames
55 minutes ago, whatnottodoingames said:
thanks gigapig but that doesnt help me get it working, just some dudes talking about modules for it
And it doesn't help that you've giving no information on what you've tried to get it working so far.
I actually did help because I doubt you even had the module which is required to get this emu running in Hyperspin/Rocketlauncher.
The Redream emulator is super simple with hardly any setup, I didn't even have to set up my Xbox controllers. Adding the module took 10 minutes.
So thanks to whatnottodoingames for giving me the heads up.
The only problem I've had is Rocketlaucher not detecting it's running.
3 hours ago, agent47 said:
Just a heads up, any current module you use won't function properly with recent versions of redream because they changed the format of the config file. I've fixed that but haven't posted it yet.
I just tested latest version of ReDream and it loads/exits and plays fine. What's the issue you are finding with latest version ?
i just arent able to quit out after i load it maybe i havent set exit key
Yes, you need to set a global exit key for your controller.
1 hour ago, agent47 said:
Some of the config file keys were changed so the module settings won't work. Namely fullscreen.
Everything working for me, including fullscreen, I did notice an issue with latest ReDream on android has an issue where it gets stuck in the main menu asking to use lite more or to purchase full version when loading, but windows version is working fine with latest version of ReDream for me.
Mine fails because Rocketlaucher doesn't detect the Redream window. I'm sure I downloaded the latest module.
