Xbox one X wireless controller script
Hi Guys,
First post here. Can anyone let me know if the startup script supports xbox one x wireless controller? Mine does not seem to work. Thank you.
50 minutes ago, gigapig said:
They should as they are also X input.
Specific buttons seem to be an issue, 90% does but the important ones don't. You need to find out which button for start etc is being pressed using Joy2Key for example and edit the ini accordingly with joy2 or joy3 etc (whatever button is incorrect)
Thank you for your replies. The script seems to be configured just fine but my controller does not control hyperspin. Once I launch a game via the keyboard the controller seems to work ok.
[Controls]
Joysticks_Enabled=True
Joysticks_MaxNumberOfJoysticks=2
Joystick_Delay=225
Joystick_Deadzone=25
Joystick_Up=JoyY-|JoyPOVN
Joystick_Down=JoyY+|JoyPOVS
Joystick_SkipUp=JoyX-|JoyPOVW
Joystick_SkipDown=JoyX+|JoyPOVE
Joystick_SkipUpNumber=Joy5
Joystick_SkipDownNumber=Joy6
Joystick_HyperSpin=JoyZ-|JoyZ+|Joy9
Joystick_Genre=Joy3
Joystick_Favorites=Joy4
Joystick_Start=Joy1
Joystick_Exit=Joy2
Joystick_Roulette=Joy7
Joystick_Volume=JoyR-
Joystick_Volume_Close=
Joystick_QuickLaunch=JoyU+
Joystick_QuickLaunch_Close=JoyU-
Joystick_Info=JoyU-
Joystick_Info_Close=JoyU+
Joystick_Filters=JoyR+
Joystick_Filters_Close=JoyR-
[Controls]
Joystick_Delay=225
Joystick_Genre=Joy3
Joystick_Start=Joy1
Joystick_Exit=Joy2
Joystick_Info=JoyU-
It's usually an issue with the Joy1 key
Test by using keyboard for select and see if others work on controller, e.g. genre, favorites and back buttons
