supermario12 Posted July 4, 2020 Posted July 4, 2020 I'm using xpadder with hyperspin and I would like to setup individual system controls for the console emulators that I have on the system as I have controllers for NES, Super NES, PlayStation, Genesis etc that work for the PC. Would there be any user able to help or is there a tutorial that would help with that? Thanks in advance for any help
dark13 Posted July 5, 2020 Posted July 5, 2020 Using xpadder with emulators that have native pad support is not a good idea, xpadder/joy2key is really useful in HyperSpin as joypad input is totally broken Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
32assassin Posted July 5, 2020 Posted July 5, 2020 Rocket launcher has the ability to assign a different controller or load a different xpadder profile to each emulator the only question is what type of controller do you have a bliss box controller --> constantly connected controller to your PC that never looses the controller ID or do you have multiple USB controllers that you connect and disconnect based on the game you are playing.
shambles1980 Posted July 6, 2020 Posted July 6, 2020 Joy2key can have profiles for different games< joy 2 key can also asign the same controller number to the joystic anytime it is connected. AHK can rebind keys for different games using #ifwinactive.. but in general if your game uses direct input controls and you want to rebind the keys its best to try and use the game settings if possible.. games like cuphead will often detect the direct input and the rebind and pop in player 2.. But when it comes to emulators.. They almost always "if not always" allow you to manually bind keys.. So I would recomend using Joy2key with a profile for the emulators.. Set the emulators to use keyboard inputs "that you have assigned in joy2key" Then add #ifwinactive scripts to your ahk module for the emulators to get the title and change the keybinds depending on the rom you are playing. (unless the game allows you to rebind the keys .. then just do that instead)
supermario12 Posted July 6, 2020 Author Posted July 6, 2020 Thank You everyone for responding that clears up alot!! And I have controllers for just about every system. So it looks like I will try the joy2key with hyperspin and if that doesn't work I'll go back to my old way of just running the games directly from the emulator without the nice frontend. Thank you everyone again!!!
