Martin17 Posted December 27, 2020 Posted December 27, 2020 I make my animations with adobe flash at first, they work fine later, the animation runs very fast, how can I solve that?Â
Aorin Posted December 27, 2020 Posted December 27, 2020 7 hours ago, Martin17 said: I make my animations with adobe flash at first, they work fine later, the animation runs very fast, how can I solve that? I believe @dark13 can help you there. Aorin
dark13 Posted December 28, 2020 Posted December 28, 2020 Hyperspin does not read the framerate of the .swf, it just play the thing as fast as it can. Use more frames to slow down the thing or use a flv with alpha channel, not embedd but read from a file. Reading a video from a file is the only way to get a perfect playback in HS with original speed and audio synced. I tried some code with timer to get a perfect playback on a .sfw, the result was the speed depended on how fast the cpu could read the code Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin Â
