src720 Posted February 24, 2021 Posted February 24, 2021 Hello all, I have been using HyperSpin with HyperHQ for a bit now and would appreciate if someone could help me with some tweaks that would make the experience a lot more enjoyable. I have been using HyperHQ to modify the wheels, but I just can't figure out the following: There is almost no delay from when I land on a game to when the artwork appears. I'd like to have at least a moment to look at the wheel and see what games are in view. Instead I have to keep scrolling to avoid having the artwork pop-in I have the wheel alpha set to 1 so that it is always visible, but is there a way to prevent artwork from covering it? Some games like Killer Instinct 1 & 2 have a graphic of a character that covers the wheel almost entirely I appreciate your help in advance. Thank you.
Spawk Posted February 24, 2021 Posted February 24, 2021 Artwork covering the wheel would have to come from the individual game themes. Personally I don't use them, just a basic default theme for an entire system. I too like the wheel visible at all times though. You could try editing them in Hypertheme. If they are using layer4, you could try moving them to a lower layer to see if they display under the wheel... or maybe remove them from the theme altogether.
Larsa Posted April 15, 2021 Posted April 15, 2021 I have the same question: - Is it possible to delay the theme/artwork/video to give your eyes a chance to rest on the wheel before the theme/artwork/video takes over? Also, Spawk mentions using a default theme. How do you set that up, and could you share what you use for your Mame theme? Finally, how do I figure out how the theme XML file works and what all of the options available in it are? Thanks!
ostadler Posted April 25, 2021 Posted April 25, 2021 I second this question. It would be great to delay the video after chosing the system. Any way to do that? Thanks for any help! Greetings, Oliver
