Hi. I was wondering if there is anyway to set Hyperpsin to load up starting at the first wheel alphabetically each time.
In a word .... no
All you can do is set HyperHQ to return to the last game you played or a random game.
An alternative way to accomplish this is to put a check in "Use Last System" in HyperHQ and then set "Last_System=" in Settings.ini to the system you want to start on. After that, set Settings.ini to read-only.
Setting files to "read-only" to retain settings/configuration is such an under-rated technique. It's never the first attempted solution but it works so well!
  • Super Like 3
Hi all
Thank you for your reply and help. I've decided to leave it on random as it's working great.
Cheers
Create an account
Register a new account
Sign in
Sign In Now
