Sorry guys, i cannot carryout anymore testing, as I am unable to update any further, as Extracting Hyperspin Core, just sits there extracting doing nothing......
Have even tried with 2.0.54, still just sits there saying Extracting Hyperspin Core.
Any ideas on things I should be doing?
I've already tried a complete new install, on a different Computer, which has made no difference.
Please help
14 hours ago, Asparky said:
Извините, ребята, я больше не могу проводить тестирование, так как не могу обновить программу, а Extracting Hyperspin Core просто сидит и ничего не делает...
try  deleting all folders hyperspin and hyperhq, and install clear fresh version HyperHq. Last version on the site - good working to me/
Have tried that, thats also why I tried a different computer, which made no difference.
I also disabled the Virus protection, incase that was doing something.
On 2/18/2025 at 9:39 AM, Asparky said:
Still unable to update the core, still sits there saying Extracting....
What’s your process for updating the core plugin?
The I have seen it get stuck on extracting before also.
close HQ and quit from system tray. Open again head to plugins tab and use the reinstall button on the plugins page.
@Asparky I hope this helps.
  1. Uninstall HyperHQ
  2. In C:\users\USERNAME
    • Delete .HyperHQ folder
    • Delete .Hyperspin folder
  3. In C:\users\USERNAME\AppData\local (You will need access to view hidden items)
    • Delete hyperhq-updater folder
  4. In C:\users\USERNAME\AppData\Roaming (You will need access to view hidden items)
    • Delete HyperHQ folder
    • Delete Hyperspin folder
  5. In C:\ProgramData
    • Delete Hyperspin
  6. Delete everything in your Hyperspin install directory.
  7. Download latest HyperHQ version from website and setup.
I was also having issues on the previous version.  I would download the lastest HyperHQ release from the websitem instead of updating, if you haven't done so?  Also, I HyperspinCore  1.1.0 might take a while to download and install.  I clicked on update, and it's been stuck on "Installing" for the past 7 minutes.  Besides that, Hyperspin is working fine so far.
I completely cleared the Program, plus the other areas it installs, downloaded the most updated system, from downloads page and let it run.
when it comes to the plugin page, the Hyperspin core downloads and just sits there Extracting, so far its been running nearly 24 Hours.
As I said, I have also tried on a different Computer, but getting the same results.
Please post your issue in the bug tracker. It needs looking into and that's the best place to keep track of it
Will do.
  • 6 months later...
These are all the files and locations where files and folders are created when installing the application. I needed to COMPLETELY WIPE my install and start from scratch.
Program Details:
Operation: Uninstall
Version: 2.0.85
Publisher: HyperSpin
Date: 9/16/2025 5:01:21 PM
Install Location: C:\Arcade\Hyperspin 2\HyperHQ
Uninstall String: "C:\Arcade\Hyperspin 2\HyperHQ\Uninstall HyperHQ.exe" /allusers
Operation Summary:
Scanning mode: Moderate
Successfully deleted Files: 10
Successfully deleted Folders: 2
Successfully deleted Registry keys: 2
Successfully deleted Registry values: 8
File and Folder operations:
C:\Users\username\AppData\Roaming\Microsoft\Windows\Recent\HyperHQ.lnk
C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E69E.pf
C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E69F.pf
C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6A0.pf
C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6A2.pf
C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6A8.pf
C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6A9.pf
C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6AA.pf
C:\WINDOWS\Prefetch\UNINSTALL HYPERHQ.EXE-4C6C23B0.pf
C:\Users\username\AppData\Roaming\Microsoft\Windows\Recent\HyperHQ-2025-09-16-20-24-29.log.lnk
c:\arcade\hyperspin 2\hyperhq
C:\Users\username\.HyperHQ
Registry operations:
HKEY_CURRENT_USER\SOFTWARE\8b57932a-6008-58c4-b0e5-3d206673fdaa
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\8b57932a-6008-58c4-b0e5-3d206673fdaa
HKEY_CURRENT_USER\SOFTWARE\8b57932a-6008-58c4-b0e5-3d206673fdaa: InstallLocation
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store: C:\Arcade\Hyperspin 2\HyperHQ\HyperHQ.exe
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store: C:\Arcade\Hyperspin 2\HyperHQ\resources\elevate.exe
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store: C:\Arcade\Hyperspin 2\HyperHQ\Uninstall HyperHQ.exe
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers: C:\Arcade\Hyperspin 2\HyperHQ\HyperHQ.exe
HKEY_CURRENT_USER\SOFTWARE\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache: C:\Arcade\Hyperspin 2\HyperHQ\HyperHQ.exe.FriendlyAppName
HKEY_CURRENT_USER\SOFTWARE\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache: C:\Arcade\Hyperspin 2\HyperHQ\HyperHQ.exe.ApplicationCompany
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\8b57932a-6008-58c4-b0e5-3d206673fdaa: InstallLocation
