Davenzd Posted February 15, 2025 Posted February 15, 2025 hi, update to hyperHQ 0.45 from 0.43 and got freeze at startup . i have also tried a clean install but the issue remain
oldhag270 Posted February 15, 2025 Posted February 15, 2025 (edited) Same here tried everything.Gets stuck installing the plugins I believe. Edited February 15, 2025 by oldhag270
rik81 Posted February 15, 2025 Posted February 15, 2025 Emulators get stuck... Mame wont unpack when adding mame to the setup either.
doozerhhh Posted February 16, 2025 Posted February 16, 2025 16 hours ago, oldhag270 said: Same here tried everything.Gets stuck installing the plugins I believe. same things
zillion23 Posted February 17, 2025 Posted February 17, 2025 You all should report this over at the bug reporting section.
Asparky Posted February 18, 2025 Posted February 18, 2025 Still unable to update the core, still sits there saying Extracting....
Asparky Posted February 22, 2025 Posted February 22, 2025 Tried to update to latest Version, just sits there as before, even tried a complete clean installation
Asparky Posted February 24, 2025 Posted February 24, 2025 Sorry guys, i cannot carryout anymore testing, as I am unable to update any further, as Extracting Hyperspin Core, just sits there extracting doing nothing......
Asparky Posted February 25, 2025 Posted February 25, 2025 Have even tried with 2.0.54, still just sits there saying Extracting Hyperspin Core. Any ideas on things I should be doing? I've already tried a complete new install, on a different Computer, which has made no difference. Please help
dreamw Posted February 25, 2025 Posted February 25, 2025 14 hours ago, Asparky said: Извините, ребята, я больше не могу проводить тестирование, так как не могу обновить программу, а Extracting Hyperspin Core просто сидит и ничего не делает... try deleting all folders hyperspin and hyperhq, and install clear fresh version HyperHq. Last version on the site - good working to me/
Asparky Posted February 25, 2025 Posted February 25, 2025 3 hours ago, dreamw said: try deleting all folders hyperspin and hyperhq, and install clear fresh version HyperHq. Last version on the site - good working to me/ Have tried that, thats also why I tried a different computer, which made no difference. I also disabled the Virus protection, incase that was doing something.
thatman84 Posted February 25, 2025 Posted February 25, 2025 On 2/18/2025 at 9:39 AM, Asparky said: Still unable to update the core, still sits there saying Extracting.... What’s your process for updating the core plugin? The I have seen it get stuck on extracting before also. close HQ and quit from system tray. Open again head to plugins tab and use the reinstall button on the plugins page. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
jesfknkrys Posted February 25, 2025 Posted February 25, 2025 @Asparky I hope this helps. Uninstall HyperHQ In C:\users\USERNAME Delete .HyperHQ folder Delete .Hyperspin folder In C:\users\USERNAME\AppData\local (You will need access to view hidden items) Delete hyperhq-updater folder In C:\users\USERNAME\AppData\Roaming (You will need access to view hidden items) Delete HyperHQ folder Delete Hyperspin folder In C:\ProgramData Delete Hyperspin Delete everything in your Hyperspin install directory. Download latest HyperHQ version from website and setup.
jesfknkrys Posted February 25, 2025 Posted February 25, 2025 I was also having issues on the previous version. I would download the lastest HyperHQ release from the websitem instead of updating, if you haven't done so? Also, I HyperspinCore 1.1.0 might take a while to download and install. I clicked on update, and it's been stuck on "Installing" for the past 7 minutes. Besides that, Hyperspin is working fine so far.
jesfknkrys Posted February 25, 2025 Posted February 25, 2025 Which core is stuck HyperspinCore 2.0.34 or HyperspinCoreEssentials 1.1.0 ?
Asparky Posted February 25, 2025 Posted February 25, 2025 1 hour ago, thatman84 said: What’s your process for updating the core plugin? The I have seen it get stuck on extracting before also. close HQ and quit from system tray. Open again head to plugins tab and use the reinstall button on the plugins page. I completely cleared the Program, plus the other areas it installs, downloaded the most updated system, from downloads page and let it run. when it comes to the plugin page, the Hyperspin core downloads and just sits there Extracting, so far its been running nearly 24 Hours. As I said, I have also tried on a different Computer, but getting the same results.
Asparky Posted February 25, 2025 Posted February 25, 2025 1 hour ago, jesfknkrys said: Which core is stuck HyperspinCore 2.0.34 or HyperspinCoreEssentials 1.1.0 ? Both
jesfknkrys Posted February 25, 2025 Posted February 25, 2025 Have you tried checking for system corruption just to narrow down your issue? sfc /scannow
thatman84 Posted February 26, 2025 Posted February 26, 2025 On 2/18/2025 at 9:39 AM, Asparky said: Still unable to update the core, still sits there saying Extracting.... Please post your issue in the bug tracker. It needs looking into and that's the best place to keep track of it Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Asparky Posted February 26, 2025 Posted February 26, 2025 37 minutes ago, thatman84 said: Please post your issue in the bug tracker. It needs looking into and that's the best place to keep track of it Will do.
jesfknkrys Posted February 26, 2025 Posted February 26, 2025 Try deleting the plugins manually. They would be located in your installation folder under plugins. then start HyperHQ to rebuild.
DrTechnolust Posted September 16, 2025 Posted September 16, 2025 These are all the files and locations where files and folders are created when installing the application. I needed to COMPLETELY WIPE my install and start from scratch. Program Details: Name: HyperHQ 2.0.85 Operation: Uninstall Size: 477 MB Version: 2.0.85 Publisher: HyperSpin Date: 9/16/2025 5:01:21 PM Install Location: C:\Arcade\Hyperspin 2\HyperHQ Uninstall String: "C:\Arcade\Hyperspin 2\HyperHQ\Uninstall HyperHQ.exe" /allusers Operation Summary: Scanning mode: Moderate Successfully deleted Files: 10 Successfully deleted Folders: 2 Successfully deleted Registry keys: 2 Successfully deleted Registry values: 8 File and Folder operations: Successfully deleted Files C:\Users\username\AppData\Roaming\Microsoft\Windows\Recent\HyperHQ.lnk C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E69E.pf C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E69F.pf C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6A0.pf C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6A2.pf C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6A8.pf C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6A9.pf C:\WINDOWS\Prefetch\HYPERHQ.EXE-0082E6AA.pf C:\WINDOWS\Prefetch\UNINSTALL HYPERHQ.EXE-4C6C23B0.pf C:\Users\username\AppData\Roaming\Microsoft\Windows\Recent\HyperHQ-2025-09-16-20-24-29.log.lnk Successfully deleted Folders c:\arcade\hyperspin 2\hyperhq C:\Users\username\.HyperHQ Registry operations: Successfully deleted Registry keys HKEY_CURRENT_USER\SOFTWARE\8b57932a-6008-58c4-b0e5-3d206673fdaa HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\8b57932a-6008-58c4-b0e5-3d206673fdaa Successfully deleted Registry values HKEY_CURRENT_USER\SOFTWARE\8b57932a-6008-58c4-b0e5-3d206673fdaa: InstallLocation HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store: C:\Arcade\Hyperspin 2\HyperHQ\HyperHQ.exe HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store: C:\Arcade\Hyperspin 2\HyperHQ\resources\elevate.exe HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store: C:\Arcade\Hyperspin 2\HyperHQ\Uninstall HyperHQ.exe HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers: C:\Arcade\Hyperspin 2\HyperHQ\HyperHQ.exe HKEY_CURRENT_USER\SOFTWARE\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache: C:\Arcade\Hyperspin 2\HyperHQ\HyperHQ.exe.FriendlyAppName HKEY_CURRENT_USER\SOFTWARE\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache: C:\Arcade\Hyperspin 2\HyperHQ\HyperHQ.exe.ApplicationCompany HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\8b57932a-6008-58c4-b0e5-3d206673fdaa: InstallLocation
