potts43 Posted July 17, 2014 Posted July 17, 2014 Hi, I've been trying to create an AHK script that runs on HS close. I want it to close xpadder and hypersearch but they won't close and remain in sys tray. I've tried turning on Detecthiddenwindows but no joy. Does anyone have a script or batch file for this? Thanks
dougan78 Posted July 18, 2014 Posted July 18, 2014 I just use taskkill and put it in the hyperhq shutdown script area.
djvj Posted July 18, 2014 Posted July 18, 2014 Process, Close, xpadder.exe Process, Close, hypersearch.exe Any icons in the taskbar notification area will remain because the taskbar was not notified those apps closed. It's a side effect of force closing executables with tray icons. The only way to get rid of them is to hover your mouse over them or force a refresh of the taskbar. The latter is not so easy. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
potts43 Posted July 18, 2014 Author Posted July 18, 2014 Process, Close, xpadder.exeProcess, Close, hypersearch.exe Any icons in the taskbar notification area will remain because the taskbar was not notified those apps closed. It's a side effect of force closing executables with tray icons. The only way to get rid of them is to hover your mouse over them or force a refresh of the taskbar. The latter is not so easy. Thanks for that info. Spent a good while doing that but hadn't realised that they were closed as they were still in tray area. I'll try that code later. Many thanks
potts43 Posted July 18, 2014 Author Posted July 18, 2014 Process, Close, xpadder.exeProcess, Close, hypersearch.exe Any icons in the taskbar notification area will remain because the taskbar was not notified those apps closed. It's a side effect of force closing executables with tray icons. The only way to get rid of them is to hover your mouse over them or force a refresh of the taskbar. The latter is not so easy. Using this code Xpadder closes but Hypersearch remains. If I try to load HS again using the startup script it tells me that there is already an instance of hypersearch running. So the close script isn't working for this program to close. Anything else I can try?
kyoken Posted July 18, 2014 Posted July 18, 2014 Try HyperSpin Startup Script here http://www.hyperspin-fe.com/forum/showthread.php?28986-HyperSpin-Startup-Script, rename it to Hyperspin Close Script in alternative folder and put any like this in cfg file: [settings] HyperLaunch_Path=C:\HyperSpin\HyperLaunch Hide_Cursor=false Hide_Taskbar=false [Keymapper] Keymapper=xpadder Keymapper_Enabled=false keymapperAhkExternalEnabled=false [Programs] Minimize_Background_Windows_Enabled=false Window_Classes_To_Not_Minimize=Shell_TrayWnd,Button Program_To_Run_Target_1= Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1= Process_Name_To_Close_1=xpadder.exe Process_Name_To_Close_2=hypersearch.exe It works 100% for me, I use HyperSpin Startup Script to launch xpadder and Hypersearch, then Use HyperSpin Close Script (same program alternative folder) to close hypersearch and xpadder, very easy.
potts43 Posted July 18, 2014 Author Posted July 18, 2014 Try HyperSpin Startup Script here http://www.hyperspin-fe.com/forum/showthread.php?28986-HyperSpin-Startup-Script, rename it to Hyperspin Close Script in alternative folder and put any like this in cfg file:[settings] HyperLaunch_Path=C:\HyperSpin\HyperLaunch Hide_Cursor=false Hide_Taskbar=false [Keymapper] Keymapper=xpadder Keymapper_Enabled=false keymapperAhkExternalEnabled=false [Programs] Minimize_Background_Windows_Enabled=false Window_Classes_To_Not_Minimize=Shell_TrayWnd,Button Program_To_Run_Target_1= Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1= Process_Name_To_Close_1=xpadder.exe Process_Name_To_Close_2=hypersearch.exe It works 100% for me, I use HyperSpin Startup Script to launch xpadder and Hypersearch, then Use HyperSpin Close Script (same program alternative folder) to close hypersearch and xpadder, very easy. Interesting....will try that later thanks mate
djvj Posted July 18, 2014 Posted July 18, 2014 Using this code Xpadder closes but Hypersearch remains. If I try to load HS again using the startup script it tells me that there is already an instance of hypersearch running. So the close script isn't working for this program to close. Anything else I can try? I don't know the executable name for hyper search. So it's probably still running because you need to fix that. Sent from my Samsung S3 using Tapatalk "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
potts43 Posted July 20, 2014 Author Posted July 20, 2014 Try HyperSpin Startup Script here http://www.hyperspin-fe.com/forum/showthread.php?28986-HyperSpin-Startup-Script, rename it to Hyperspin Close Script in alternative folder and put any like this in cfg file:[settings] HyperLaunch_Path=C:\HyperSpin\HyperLaunch Hide_Cursor=false Hide_Taskbar=false [Keymapper] Keymapper=xpadder Keymapper_Enabled=false keymapperAhkExternalEnabled=false [Programs] Minimize_Background_Windows_Enabled=false Window_Classes_To_Not_Minimize=Shell_TrayWnd,Button Program_To_Run_Target_1= Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1= Process_Name_To_Close_1=xpadder.exe Process_Name_To_Close_2=hypersearch.exe It works 100% for me, I use HyperSpin Startup Script to launch xpadder and Hypersearch, then Use HyperSpin Close Script (same program alternative folder) to close hypersearch and xpadder, very easy. Using this script I get the same result. Xpadder closes but hypersearch remains running. I'm wondering if it is a UAC permissions issue.
ghutch92 Posted July 20, 2014 Posted July 20, 2014 Try HyperSpin Startup Script here http://www.hyperspin-fe.com/forum/showthread.php?28986-HyperSpin-Startup-Script, rename it to Hyperspin Close Script in alternative folder and put any like this in cfg file:[settings] HyperLaunch_Path=C:\HyperSpin\HyperLaunch Hide_Cursor=false Hide_Taskbar=false [Keymapper] Keymapper=xpadder Keymapper_Enabled=false keymapperAhkExternalEnabled=false [Programs] Minimize_Background_Windows_Enabled=false Window_Classes_To_Not_Minimize=Shell_TrayWnd,Button Program_To_Run_Target_1= Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1= Process_Name_To_Close_1=xpadder.exe Process_Name_To_Close_2=hypersearch.exe It works 100% for me, I use HyperSpin Startup Script to launch xpadder and Hypersearch, then Use HyperSpin Close Script (same program alternative folder) to close hypersearch and xpadder, very easy. This post and the upcoming HyperLaunch has inspired me to update my startup script. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
