Haven't had time to work on much for a while but this is what I'm working on: Super Bikes 3
And here's an animation test for the idea I have about swapping the bike colors from the multiplayer marquees.
  • Super Like 5
Super Bikes 3 (SB3) continued...
Here is the reference image for the 4 bike colors:
Multiple layers to achieve color and spark effects:
Combined together:
And here's the near-final result (need to move bike in from off-screen and add hover):
Chase H.Q. 2 (2007)
Based on the sideart. I had to use a bunch of images for reference - and many, many attempts - but AI did the heavy lifting to recreate the badge. I had to touch up details and some of the text by hand. The background was pretty easy. Basically just typed "remove the text and logos" and filled in where the cabinet edges were cut.
AI couldn't get the side text clear enough for my liking, so "POLICE EMERGENCY" and "Chase H.Q. is back!" was redrawn in Illustrator.
To create the shine/reflection effect on the logo and badge, I placed a brighter copy of each image on top and used the reveal effects/shaders combined with opacity (40% down to 0% so the brighter layer fades as it's revealed).
And here's the result in action:
Winter X Games SnoCross
The marquee for the game is made of multiple layers of plexiglass, so I thought it would be cool to lean into that idea for the theme.
Each layer has that look including a custom video frame layer.
To achieve the look, I used several layers.
And the final theme:
GRID
Based on the marquee:
A technique for simple video borders - like the one I used in this theme:
-Apply layer styles to the snapshot that you use when mocking up the theme in Photoshop (stroke, drop shadow, outer glow etc.)
-Change the fill of that layer to 0%. This will leave only the effects visible.
-Convert that layer to a smart object
-export the layer as a png (or just import the whole Photoshop file into HyperTheme, and it will make that smart object layer a png for you)
Note: If you're using a drop shadow with this method, make sure "Layer Knocks Out Drop Shadow" is selected
Wild West Shootout
I cut up the characters so I could animate them. I primarily used the smudge tool (set to about 85% strength) to fill in the cut sections.
Here are the characters animated:
Nicktoons Nitro Racing
I used a bunch of layers to animate all the parts:
For the moving background, I created a super-sized checkerboard circle in Illustrator and set a slow rotation. This image shows the theme canvas in relation to the circle:
And here it is all together and animated:
Virtua Cop 3
I used a bunch of reference images for the logo and shield/badge and redrew them in Illustrator. Once it was drawn, I could separate the parts to animate them individually.
Ollie King
First I cut out the skater with the pen tool and created a vector mask. Then I upscaled and vectorized it. I created copies of that layer and used the Layer Style/Color Overlay to make the multiple green shadow layers. And then I added one more additional layer with the yellow outline.
I created the video shadow layers in the same colors.
I then redrew all the arrows so I could animate them separately.
And finally I made a bg and theme border similar to the marquee.
Final result:
