Emu54 Posted August 20, 2014 Posted August 20, 2014 Hi my drive with hyperspin on it what u think I should do I ran CrystalDiskInfo and got a caution on my drive that has hyperspin on got a yellow tab that says Reallocated Sector Count current 100 worst 100 threshold 36 000000000180 them temp is 27c and smart test passed and help be great can get a new drive but don't really wont just throw away if can help it.
Agrajag Posted August 20, 2014 Posted August 20, 2014 Step 1: Backup the drive if you haven't already done so, to avoid losing everything if it fails. (This goes without saying, but it seems to be a common topic of conversation around here and the site where we get the games from!) Step 2: Google the error and read one of the many discussions about reallocated sectors, such as this one: http://www.techpowerup.com/forums/threads/reallocated-sectors-count-should-i-be-worried.165635/ Step 3: Make up your own mind about whether your drive is genuinely failing or is just behaving as hard drives normally do. Personally, I never scrutinise my drives for errors apart from when I buy them. I keep at least two copies of all my data, and the drives in my PCs get upgraded to larger ones every so often anyway. A drive failure should always be an inconvenience, not a disaster. EDIT: just thought the above may come across as patronizing, but it was meant in the spirit of helping others to help themselves. Sent from my phone using Tapatalk, probably while at work... HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
jamaster14 Posted August 20, 2014 Posted August 20, 2014 Step 1: Backup the drive if you haven't already done so, to avoid losing everything if it fails. (This goes without saying, but it seems to be a common topic of conversation around here and the site where we get the games from!)Step 2: Google the error and read one of the many discussions about reallocated sectors, such as this one: http://www.techpowerup.com/forums/threads/reallocated-sectors-count-should-i-be-worried.165635/ Step 3: Make up your own mind about whether your drive is genuinely failing or is just behaving as hard drives normally do. Personally, I never scrutinise my drives for errors apart from when I buy them. I keep at least two copies of all my data, and the drives in my PCs get upgraded to larger ones every so often anyway. A drive failure should always be an inconvenience, not a disaster. EDIT: just thought the above may come across as patronizing, but it was meant in the spirit of helping others to help themselves. Sent from my phone using Tapatalk, probably while at work... couldnt agree more with these general practices. anytime i add something to hyperspin and having a good, working, updates configuration i make a backup image. once you've done that you'll always be covered and worse case your out a few bucks for a new hard drive
Emu54 Posted August 22, 2014 Author Posted August 22, 2014 I got a new drive backed everything up put the other drive in a external case and put files on that i wont to keep but can get again if needed thanks for the info and advice
Agrajag Posted August 22, 2014 Posted August 22, 2014 No problem. Better to be safe than sorry, eh? HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
xagesz Posted August 22, 2014 Posted August 22, 2014 I run a large NAS at my house so I keep all my data backed up on there. "Pinball Unknown" - 46/30/DMD - A work in Progress Kick it Harder
Agrajag Posted August 22, 2014 Posted August 22, 2014 Likewise, although I filled mine up and had to buy another one... HyperSpin behaving oddly? Read about known bugs here: http://www.hyperspin-fe.com/topic/4590-known-bugs-and-handy-hints-for-hyperspin/ The installer for HyperSpin now includes HyperLaunch 2. Go here for support: http://www.hyperspin-fe.com/forum/122-hyperlaunch-2/ HyperLaunch3 is now called RocketLauncher. Go here for support: http://www.rlauncher.com/forum/content.php Read this for ftp login info: http://www.hyperspin-fe.com/topic/2320-ftp-access-must-read/ Platinum members get 25% off an Emumovies subscription: http://www.hyperspin-fe.com/topic/1211-emumovies-code/
craiganderson Posted August 23, 2014 Posted August 23, 2014 I'm backing up my system right now. Had a little scare today..... http://craigandersonthemes.weebly.com/
