Mr Black Arm Posted July 22, 2011 Posted July 22, 2011 So I came across a Fight! theme and decided to add it to my wheel setup. My question is what emulator do you use? I assume MAME, however, I know some games run better on psxMAME or Zinc. Has anyone added this to their cab and if so, how did they go about it? Also, if someone have a Fight! video compliation, that would be great too.
volumetric Posted July 22, 2011 Posted July 22, 2011 psxMAME is basically a version of mame that uses zinc's rendering plugin (i think, or maybe it uses the same plugins as epsxe, one of the two anyway). It is essentially identical in terms of setup as mame. It is probably (imho) the better alternative than zinc, it runs more games than zinc, and it is less of a pain than zinc to set up. Zinc uses a numbered rom system that can be very annoying to deal with. Also setting up controls in zinc can be a pain. So psxMAME would be my first choice. Also, if you are setting up a fight theme, and you haven't done so already, check out Naomi emulation via either makaron or demul. Then you could add stuff like guilty gear, power stone, project justice and doa2. And of course no fighting theme would be complete without marvel vs capcom 2. One final thing, you may want to incorporate model 2, just for virtua fighter 2
Mr Black Arm Posted July 23, 2011 Author Posted July 23, 2011 I'm pretty much just basing it off the Fight theme (created here) and the KB Fight wheel set. I'm not sure how to setup one wheel for multiple systems or if you can. Didn't know if anyone tried to create the same thing and how they did it?
DemonEyeX Posted July 23, 2011 Posted July 23, 2011 To add multiple systems to a single wheel, Using the 'Fight' wheel as an example. When you add a game to your Fight XML (Databases folder), do it like this :- <game name="vf2"> <description>Virtua Fighter 2</description> <cloneof></cloneof> <crc></crc> <manufacturer>Sega</manufacturer> <year></year> <exe>Sega Model 2</exe> <genre></genre> </game> <game name="mvsc2"> <description>Marvel vs Capcom 2</description> <cloneof></cloneof> <crc></crc> <manufacturer>Capcom</manufacturer> <year></year> <genre></genre> <exe>DemulNaomi057</exe> </game> e.t.c. This line......... <exe>Sega Model 2</exe> Tells HS all it needs to know. Just make sure all the names match your setup and you're away !
Mr Black Arm Posted July 23, 2011 Author Posted July 23, 2011 To add multiple systems to a single wheel,Using the 'Fight' wheel as an example. When you add a game to your Fight XML (Databases folder), do it like this :- <game name="vf2"> <description>Virtua Fighter 2</description> <cloneof></cloneof> <crc></crc> <manufacturer>Sega</manufacturer> <year></year> <exe>Sega Model 2</exe> <genre></genre> </game> <game name="mvsc2"> <description>Marvel vs Capcom 2</description> <cloneof></cloneof> <crc></crc> <manufacturer>Capcom</manufacturer> <year></year> <genre></genre> <exe>DemulNaomi057</exe> </game> e.t.c. This line......... <exe>Sega Model 2</exe> Tells HS all it needs to know. Just make sure all the names match your setup and you're away ! Awesome man, makes perfect sense. Thanks!
Mr Black Arm Posted July 29, 2011 Author Posted July 29, 2011 Quick question. Do I use the name of the system (i.e Sega Naomi) or the name of the exe (demul.exe)?
DemonEyeX Posted August 9, 2011 Posted August 9, 2011 Ummmm, sorry 'bout the mad long time it took for me to reply dude. I'm guessing that you worked it out, However, just to clarify..... Use the system name (i.e. the name of your settings \ database xmls).
Mr Black Arm Posted August 9, 2011 Author Posted August 9, 2011 Ummmm, sorry 'bout the mad long time it took for me to reply dude.I'm guessing that you worked it out, However, just to clarify..... Use the system name (i.e. the name of your settings \ database xmls). Hahaha, no problem dude. Yeah, I got that part figured out. I apprecaite it. As far as emulators and rom paths in HyperHQ, where do I point those since there are different emus and roms?
DemonEyeX Posted August 10, 2011 Posted August 10, 2011 As far as emulators and rom paths in HyperHQ, where do I point those since there are different emus and roms? Do you mean specifically for your 'Fight' wheel ? If so, as long as the emulators you plan to use for your 'Fight' wheel are already set up & working in HS (and the roms you plan on using are already listed in the necessary Database XML), then you should be good to go. For your 'Fight' settings, you can leave these blank, as long as your 'Fight' XML has the <exe>Sega Model 2</exe> line set for each game, However, I would probably suggest using MAME as the backbone to the 'Fight' wheel, as many\most of the games you're gonna want are emulated by MAME. You can point HS to the same version of MAME that you are already using if you like. Hope you get me dude, sorry if i'm rambling\confusing, I need sleeeep. Good luck. Peace.
Mr Black Arm Posted August 11, 2011 Author Posted August 11, 2011 Do you mean specifically for your 'Fight' wheel ?If so, as long as the emulators you plan to use for your 'Fight' wheel are already set up & working in HS (and the roms you plan on using are already listed in the necessary Database XML), then you should be good to go. For your 'Fight' settings, you can leave these blank, as long as your 'Fight' XML has the <exe>Sega Model 2</exe> line set for each game, However, I would probably suggest using MAME as the backbone to the 'Fight' wheel, as many\most of the games you're gonna want are emulated by MAME. You can point HS to the same version of MAME that you are already using if you like. Hope you get me dude, sorry if i'm rambling\confusing, I need sleeeep. Good luck. Peace. Yeah, most (if not all) games are on MAME, so I will set my emu and rom path settings for fight.ini to the same as MAME. Will be testing it out soon. Eventually, I'd like to set up multiple emulators for systems like Naomi, PSX, etc.
