[Release] HyperSpin XML Bidouilleur 0.1
  • Replies 99
What you can do is to look into 'lang' folder. Just delete fr.qm, and rename en.qm to fr.qm.
Until i'm ok for continue coding
You suggestion are always good Skitprat ;) Better language handling will be here with the next release
Thanks for your answer!
I actually tried the language thingie you suggested earlier but the result is the same. Still french. No idea where the french comes from when I only have an english language file :(
A huge thanks, Ski-lleR!! It works like a charm and the language is English. Finally I understand hehe. Once again, thanks for making this tool and for taking your time to help me!
  • 4 weeks later...
Ski-lleR, thank you very much for this awesome program!
It adds a completely new dimension to using HyperSpin.
Fantastic.
I did notice a missing feature however:
HyperSpinXMLBidouilleur does not resolve relative paths, while HyperHQ and HyperSpin do.
So, in HyperHQ, under the Wheel Management, Emulator tab, I can use '..\..\' notation so that paths to Executable and Rom Path are relative.
And it works like a charm.
However, in HyperSpinXMLBidouilleur, under Roms Management, when the Roms folder is written this way, and I click 'Analyse' the HyperSpinXMLBidouilleur gives me 'Roms folder doesn't exist!' error.
When I manually type in the full absolute path in Roms folder input box, then it works as it should.
So, the obvious conclusion is that HyperSpinXMLBidouilleur doesn't know how to resolve relative path notation.
It would be great if you can fix that.
Thanks!
:pcguru:
Ski-lleR this app is the $hit. What was taking me days to do now only takes minutes. I cannot however get the "get info" button to work. Most of the time it just sits there. Other times it will say nothing found and give an error and i have to quit and restart the app. I noticed in the window that pops up, it reads gamesdbase.cm instead of .com dont know if that has anything to do with it but i figured i would mention it.
Either way this app is wonderful and i cannot wait for the genre section of the app to work. Will we be seeing this soon?
Hi
I have multiple project on the road, so to be honest, i can't give release date. I can just say: when i find time
But all discovered bug and missing/promise function will be for the next release.
  • 1 month later...
Hi
I would like to make a suggestion.
Would it be possible to make a button to change the status of "enabled Yes/No" according to the renamed roms you have in your rom folder, so only the roms that we have appear in hyperspin
It would not be necessary to delete the lines in the XML file.
I know this will no longer be necessary in hyperspin2.0 but for now it would be cool.
thanks for reading
great software ...
  • 3 weeks later...
merci pour ce super programe.
Alors apres test: La list de roms ne depasse jamais la lettre B, est ce normal ? ( limite de roms ???)
C'est dommage car il est vraiment sympa pour ajouter les videos.
  • 4 weeks later...
For our English readers, berni is saying that his ROM list never gets past the letter B and asks if there's a limit to the number of ROMs that can be added. I am also having the same issue but with NES and a few other consoles never going past S.
EDIT: After taking a closer look, it looks like the app is choking on the "+" character anytime it shows up in a ROM name. The last ROM on the list will always be one with a + in it (unless you have a ROM with another special character that forces it to the end of the list).
French: Pour moi, c'est a cause des ROM avec un "+" dans le nom, chaque fois.
Très bonne application,
Juste une fonction de plus serait la bienvenue.
Voilà, de la même manière que l'on compare le nom des artworks et vidéos par rapport a son xml de base,cela permettant de les nommer correctement, il serait bien aussi de pouvoir faire la même chose avec les thèmes zippés...je m'explique....
j'utilise pour MAME la version 0.139 et cela depuis le début, hors, les thèmes des jeux qui sont disponibles le sont pour la 0.144, et au vue des nombreuse updates de cet émulateur certains jeux n'ont plus tout a fait le même nom, et il est très difficile de savoir les quels.
il existe bien http://www.progettosnaps.net/renset_en.html mais il renomme automatiquement et n'est pas très précis.
je pensais donc a cette option supplémentaire cela permettrait de nettoyer et mettre a jour proprement sa liste de thèmes pour MAME.
@ zerojay & berni
Use HS Total Editor app to fix the XML. Then it will work with this tool.
French: Utilisez app HS éditeur totale pour fixer le XML. Puis ce sera le travail avec cet outil.
Great software, but when I make changes to the XML I've downloaded from Hyperlist, the index ability messes up and I can't jump to a certain letter by holding left or right, a "?" just shows up. Any ideas?
  • 4 weeks later...
Excellent tool! I used it to help audit all of my artwork. I can't wait until you have the Genre section working. Thanks :)
  • 1 month later...
Love this tool! However, I'd like to complete the translation (or at least do what parts I can), but the source isn't available anywhere. Couldn't you throw it up on Github or something?
Great app! the only bug i found is when i hit he button "Wheel" or "Box art" to sort it out to the list does not do nothing. only the "title" is working. I don't know if anyone else noticed this.
amazing tool as well, unfortunately when scanning for missing artworg, videos are only scanned as flv. but hyperspin accepts PNG instead of FLV as well.
rgds
alex
I noticed also that!
Thanks for sharing this app!
