JohnnyChimpo Posted January 17 Posted January 17 Anyone had luck with Playstation games launching in HS with either Retroarch or Duckstation? I have 3 Playstation games and can't get any to work inside HS. They work in Retroarch and Duckstation separately. I have the defualt emulator to duckstation.
32assassin Posted January 17 Posted January 17 I had multiple systems installed and none of them worked, this was because the retorarch core was not added tot he list 1. click on Platform tab 2. click on the RetroArch tab 3. click on supported systems 4. make sure that the system you want is listed and has the core assigned to the system. I had to manually add a few PSX was one of them.
JohnnyChimpo Posted January 17 Author Posted January 17 3 hours ago, 32assassin said: I had multiple systems installed and none of them worked, this was because the retorarch core was not added tot he list 1. click on Platform tab 2. click on the RetroArch tab 3. click on supported systems 4. make sure that the system you want is listed and has the core assigned to the system. I had to manually add a few PSX was one of them. This was needed. I enabled swanstation in Retroarch as you suggested. Now if i try and launch a PS game from HQ it tries then crashes HQ. If i launch a game from HS it goes to the spinning "loading" Hyperspin screen and never loads. I have to quit HS via task manager... Duckstation will launch the games outside of HQ/HS but I can't seem to get HQ to work with Duckstation Emulator either
rudealleycat Posted January 18 Posted January 18 (edited) I am in the same boat. Unfortunately I didn't see this post hours ago when I started troubleshooting the issue. I was able to figure out what @32assassin suggested. However I will tell you that the built in BIOS for Swanstation is not good. You MUST source a BIOS to use and place it in the folder below. C:\HyperSpin\emulators\RetroArch\system The file path may vary based on where your HyperSpin folder is located. I've heard of a way to get a usable Playstation BIOS from the PS3 update file. I will not post anymore about that as I am not sure about the legality of this method to obtain the BIOS. The only problem I have now is getting HyperSpin to work properly after exiting the game that is running in RetroArch... Edited January 18 by rudealleycat accidentally submitted post before it was finished
JohnnyChimpo Posted January 19 Author Posted January 19 Saved the proper BIOS for PS1, both ps1_rom.bin and scph5501.bin in the C:\HyperSpin\emulators\RetroArch\system folder. Retroarch suggest the BIOS for PS1 US are present, but I can't seem to get any PS1 games to launch in Retroarch via Swanstation and thus not is HS either. Frustrated... thanks for the help @rudealleycat, I've made some progress (i think) but not haven't solved it yet. Anyone get PS1 games to launch in Retroarch? Quote
32assassin Posted January 20 Posted January 20 what format are your games, at some point we had to mount bin, cue files on virtual drives in order to play the games. if you are upgrading your Hyperspin setup, now is the time to replace your files if you don't have CHD files for your disc based games. CHD = Compressed Hunks of Data ( will save you allot of drive space compared to most of the other formats)
JohnnyChimpo Posted January 20 Author Posted January 20 23 minutes ago, 32assassin said: what format are your games, at some point we had to mount bin, cue files on virtual drives in order to play the games. if you are upgrading your Hyperspin setup, now is the time to replace your files if you don't have CHD files for your disc based games. CHD = Compressed Hunks of Data ( will save you allot of drive space compared to most of the other formats) Ironically I was able to upload most of my old games from previous Hyperspin 1.5 setup to 2.0 without much problem. I only have 3 playstation games thus far which I have sourced recently. They are all bin files with one .cue. Example below. I tried removing all the BIN and Cue files for the games from the sub folders and just having them in the "playstation folder" but that didn't seem to help. Retroarch keeps saying "Failure to boot". These games as organized will play separately in Duckstation... just can't get Retroarch to launch them.
JohnnyChimpo Posted January 20 Author Posted January 20 Update: I got HW to launch the Playstation games via Duckstation, but Duckstation and HS don't play great together... When i exit the game it pulls up the Duckstation menu and then HS gets stuck and I have to kill it via task manager. Would love to get Retroarch to work with Playstation...
32assassin Posted January 22 Posted January 22 I have the same issue with BigPEmu (Atari Jaguar CD) the issue is with the emulator not HS or HQ. The emulator users the EXT key to navigate the emulators system menu it might need a custom exit script so that the emulator closes when you press the EXT key and not bring up the emulator menu.
JohnnyChimpo Posted January 22 Author Posted January 22 19 hours ago, 32assassin said: I have the same issue with BigPEmu (Atari Jaguar CD) the issue is with the emulator not HS or HQ. The emulator users the EXT key to navigate the emulators system menu it might need a custom exit script so that the emulator closes when you press the EXT key and not bring up the emulator menu. Oh... interesting. Let me know if you solve it with the exit script.
32assassin Posted January 24 Posted January 24 I figured out the Exit issue with BigPEmu, it might work for Duckstation too but Retroarch with the swansation core and CHDs will load and exit for me the guys at Launchbox had the same issue https://forums.launchbox-app.com/topic/71470-atari-jaguar-on-bigpemu-emulator-what-command-line-is-needed-to-exit-the-game-when-pressing-esc/ unfortunately the script they are using did not work for HQ, I had to modify it (slightly) 1. click on the platforms icon 2. click on the emulator 3. click on the running script 4. type in $Esc:: { ProcessClose("BigPEmu.exe") } 5. save the changes If you need to access the emulators system menu you will need to load the emulator OUTSIDE of HQ or HS, as this script will exit the emulator when you press the ESC key. try and see if it works for Duckstation, obviously you will need to change the ProcessClose("NAME.exe") to match the name your emulator exe. 1 1
thatman84 Posted January 25 Posted January 25 On 1/20/2026 at 3:44 PM, JohnnyChimpo said: Update: I got HW to launch the Playstation games via Duckstation, but Duckstation and HS don't play great together... When i exit the game it pulls up the Duckstation menu and then HS gets stuck and I have to kill it via task manager. Would love to get Retroarch to work with Playstation... I was just playing with this and @32assassin thread linked. I have set the DuckStation "Open Pause Menu" Hotkey to P instead of Escape. I have set the "Power Off System" Hotkey to Escape In the HyperHQ Platform settings for DuckStation I added the -batch command to the launching. Seems to work fine with latest releases of HQ and HS 1 Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
JohnnyChimpo Posted January 25 Author Posted January 25 Thank you. Made these changes. Duckstation launching games no problem. No luck in Hyperspin. It's telling me the Path to ROMS doesn't exist... its the same path as Duckstation... what am I missing?
thatman84 Posted January 26 Posted January 26 22 hours ago, JohnnyChimpo said: Thank you. Made these changes. Duckstation launching games no problem. No luck in Hyperspin. It's telling me the Path to ROMS doesn't exist... its the same path as Duckstation... what am I missing? are your games in individual folders? Under the edit pencil on the game in HyperHQ check the game paths see if its got the actual file and extension Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
JohnnyChimpo Posted January 27 Author Posted January 27 6 hours ago, thatman84 said: are your games in individual folders? Under the edit pencil on the game in HyperHQ check the game paths see if its got the actual file and extension Here's the path in HyperHQ and the path in Duckstation, and folder on the F drive. Do I need to somehow tell HyperHQ to choose the .cue file?
thatman84 Posted January 27 Posted January 27 Yes HyperHQ is sending the folder not the cue file. you can try deleting and importing again. Turn on search subfolders in the import wizard Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
JohnnyChimpo Posted Wednesday at 02:52 PM Author Posted Wednesday at 02:52 PM On 1/26/2026 at 11:08 PM, thatman84 said: Yes HyperHQ is sending the folder not the cue file. you can try deleting and importing again. Turn on search subfolders in the import wizard Ugh... tried this. Still no go. Sorta at a loss. I still don't understand why Retroarch won't launch these games either.
32assassin Posted Wednesday at 03:51 PM Posted Wednesday at 03:51 PM your game paths don't add up one is F:\ROMS\Playstation\ and the other is F:\ROMS\Sony Playstation\ but I guess if you updated that remove any extra extensions from the system set up and only have the CUE file.
JohnnyChimpo Posted Friday at 06:13 PM Author Posted Friday at 06:13 PM On 1/28/2026 at 7:51 AM, 32assassin said: your game paths don't add up one is F:\ROMS\Playstation\ and the other is F:\ROMS\Sony Playstation\ but I guess if you updated that remove any extra extensions from the system set up and only have the CUE file. I did fix this previously... UPDATE: I converted my game filed to CHDs and messed around with the BIOS setting in Retroarch and manged to get Retroarch to launch the PS1 games via swanstation (Hurray!!). Now, for whatever reason I can't get Hyperspin or HyperHQ to launch them. I have enabled Swanstation in the Supported Systems in Retroarch, I have made sure .chd is in the Extension Filters for Sony Playstation, Retroarch is my default emulator... what do I have wrong? Do I need to somehow set up Swanstation as the default core in Retroarch?
thatman84 Posted Friday at 09:39 PM Posted Friday at 09:39 PM Glad you got the games running in Retroarch. I assume you were testing by opening Hyperspin/emulators/Retroarch/retroach.exe see what your game paths are showing in HyperHQ systems-> Sony PlayStation -> Games and hit the edit pencil and choose game paths. you may need to rescan if you haven’t done so since updating the games to CHD Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
32assassin Posted 19 hours ago Posted 19 hours ago The only thing I could say that is possible wrong with your current set up is 1. remove the bin extension from your list, Retroarch only uses the Cue file to load the game you also don't want to add any bin files to your game list 2.open the cue file in notepad++ ( do not know if notepad will work) and make sure that all the bin files (with the correct name are listed) but your game loads directly from the emulator (I do not see how this is could be a problem) 3. Seems like a dumb thing to ask but, this was an issue for me Open Retroarch and go to the Online updater -- Core downloader make sure that all the cores listed on HQ are actually downloaded. I'm only using SwanStation because HQ suggested it, I had to download the core because I was using the Beetle or PCSX core on my previous setup
JohnnyChimpo Posted 16 hours ago Author Posted 16 hours ago On 1/30/2026 at 1:39 PM, thatman84 said: Glad you got the games running in Retroarch. I assume you were testing by opening Hyperspin/emulators/Retroarch/retroach.exe see what your game paths are showing in HyperHQ systems-> Sony PlayStation -> Games and hit the edit pencil and choose game paths. you may need to rescan if you haven’t done so since updating the games to CHD 2 hours ago, 32assassin said: The only thing I could say that is possible wrong with your current set up is 1. remove the bin extension from your list, Retroarch only uses the Cue file to load the game you also don't want to add any bin files to your game list 2.open the cue file in notepad++ ( do not know if notepad will work) and make sure that all the bin files (with the correct name are listed) but your game loads directly from the emulator (I do not see how this is could be a problem) 3. Seems like a dumb thing to ask but, this was an issue for me Open Retroarch and go to the Online updater -- Core downloader make sure that all the cores listed on HQ are actually downloaded. I'm only using SwanStation because HQ suggested it, I had to download the core because I was using the Beetle or PCSX core on my previous setup Thank you both. Getting closer! I deleted and rescanned the games, removed .bin from the extensions and I got the games to launch from HyperHQ, but with one issue. For some reason Hyper HQ is showing two game options for each (see below). The second launches, the top one doesn't. Default is to try the top one, so if I click "Play Now" or try to launch from HyperSpin it doesn't work as it's trying for that top one. How do I get rid of that version?
32assassin Posted 15 hours ago Posted 15 hours ago you more than likely have two paths listed on your game path settings delete the extra path or delete the games and re scan your game directory so it only adds the path to the cue files.
JohnnyChimpo Posted 12 hours ago Author Posted 12 hours ago 4 hours ago, 32assassin said: you more than likely have two paths listed on your game path settings delete the extra path or delete the games and re scan your game directory so it only adds the path to the cue files. Boom! I deleted the system and games and added fresh. Somehow with only one game path there's still 2 versions, but now the correct version is first so HyperSpin and HyperHQ are both launching them correctly. Thank you! I really appreciate the help... Now if I can just figure out why HyperSpin freezes everytime I exit a game instead of returning to the wheel menu...
