Hyperspin Wheels not working.
Thommo
Hi all,
I probably have missed something simple but I have put Hyperspin on the PC and now hyperspin launches into the main menu wheel only. When I press Enter to open up a system(MAME for example or any of the other systems) instead of opening up to the system theme and wheel the screen goes black and then comes back to the main menu wheel sitting on MAME wheel image.
Also instead of the ESC button exiting Hyperspin it freezes/pauses the transitions/videos etc on the theme. When ESC is pressed again it unpauses.
I have tried changing both keys for esc and enter in hyperlaunch with no success. Currently the only way that I can exit is to use taskmanager to endtask.
P.S. I should add that I can launch MAME through Hyperlaunch with no issues at all. For the life of me I cannot see why none of the system wheels are working.
The funny thing is that I have this working well on my laptop with no issues at all until transfering it to the PC. I thought that something may have been missed in the transfer so I installed it all again and the same problem exists.
Some guidance or help on where to look first would be very much appreciated.
1st thing to check would be that your hyperspin\database\mame\ folder has an mame.xml in it. Also, how are you launching mame with hyperlaunch if you cant get into the mame wheel? Another thing to check would be your settings in hyperHQ, if you have mame set to show only themes/wheel, and you have no themes or wheel art, this can happen.
Hi volumetric,
Yep, deffinintly a MAME xml file in there. There are xml's for all the different systems. This happens on any system that I try to open in Hyperspin.
I can open MAME using Hyperlaunch 2.07 which workes fine. This isnt going into hperspin so the wheel issue isnt a problem.
The problem for me seems to be that the enter and es keys dont do as they are supposed to (for some reason) and that I cannot open up any of the system wheels/themes when I press enter on it (MAME was just an example as it happens with all the system)
To help clarify what is happening.
07:14:39 PM | HyperSpin Started
07:14:39 PM | Going FullScreen
07:14:39 PM | Checking for updates
07:14:39 PM | Update Check Complete
07:14:39 PM | Startup program unavailable
07:14:39 PM | Playing intro video
07:14:41 PM | Error intializing joysticks
07:14:41 PM | Menu Mode is multi
07:14:41 PM | Loading Main Menu.xml
07:14:41 PM | Main Menu.xml successfully loaded
07:14:42 PM | Main Menu wheel loaded successfully
07:14:57 PM | Loading Main Menu.xml
07:14:57 PM | Main Menu.xml successfully loaded
07:14:58 PM | Main Menu wheel loaded successfully
07:15:04 PM | Loading Main Menu.xml
07:15:04 PM | Main Menu.xml successfully loaded
07:15:05 PM | Main Menu wheel loaded successfully
07:15:20 PM | Loading Main Menu.xml
07:15:20 PM | Main Menu.xml successfully loaded
07:15:21 PM | Main Menu wheel loaded successfully
It seems as though when I want to open up a system wheel/theme(MAME for example) it loades up the Main Menu.xml instead of the system .xml for some reason. This happens on all of the systems that I try to load. It explains why the main menu is reloading all the time.... as that is what is happening.
Can someone point me in the direction where I need to go to look to see why this would be happening.
Plus my settings.ini just incase something is stuffed up.
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
[HyperLaunch]
exit_script_key=~q & ~s
exit_emulator_key=~Esc
toggle_cursor_key=~t
hide_cursor=false
hide_desktop=false
hide_taskbar=false
path_to_daemontools=
path_to_cpwizard=
cpwizard_delay = 8000
cpwizard_params = -timeout 9000
last_system=MAME
last_rom=alexkidd
[Resolution]
FullScreen=true
Width=800
Height=600
Scanlines_Active=false
Scanlines_Image=
Scanlines_Scale=2
Scanlines_Alpha=0.1
[Optimizer]
CPU_Priority=normal
Quality=HIGH
Image_Smoothing=true
Animated_Backgrounds=true
Inter_Backgrounds=false
Level1_Backgrounds=true
Level2_Backgrounds=true
Level3_Backgrounds=false
Level4_Backgrounds=false
Special_Backgrounds=true
Wait_For_Special=false
Animated_Artworks=true
Level1_Artworks=true
Level2_Artworks=true
[introVideo]
Use_Intro=true
Stop_On_Keypress=true
[sound]
Master_Volume=100
Video_Volume=100
Wheel_Volume=20
Interface_Volume=100
[AttractMode]
Active=true
Time=60
MaxSpinTime=10
HyperSpin=true
Wait_For_Video=false
[Keyboard]
Key_Delay=false
[P1 Controls]
Start=13
Exit=27
Up=38
Down=40
SkipUp=37
SkipDown=39
SkipUpNumber=70
SkipDownNumber=86
HyperSpin=32
Genre=71
Favorites=76
[P2 Controls]
Start=69
Exit=81
Up=87
Down=83
SkipUp=65
SkipDown=68
SkipUpNumber=74
SkipDownNumber=77
HyperSpin=88
Genre=72
Favorites=90
[P1 Joystick]
Enabled=false
Joy=0
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
SkipDown=Analog_Right
SkipUpNumber=Button_3
SkipDownNumber=Button_4
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[P2 Joystick]
Enabled=false
Joy=1
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[Trackball]
Enabled=false
Sensitivity=90
[spinner]
Enabled=false
Sensitivity=90
[startup Program]
Executable=
Paramaters=
Working_Directory=
WinState=
[Exit Program]
Executable=
Paramaters=
Working_Directory=
WinState=NORMAL
[LEDBlinky]
Active=false
Path=
[HiScore]
Active=false
Y=550
Delay=2
I'm not going to be able to add much value to this thread, but for what it's worth I have the exact same issues. Just moved a fully functioning Hyperspin to a new PC and am now having these issues.
If you are using HyperHQ Wizard to create systems, you will never have a problem like this. Do NOT move one setup from one PC to the next unless you have full understanding of how HS and it's dir structure and xmls work.
Start with a fresh install and you will eventually see where you went wrong.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Thanks djvj,
Problem is that when I had the issue with moving the set-up from the laptop to the PC I then made a complete new install and I'm still having the same issue. The only things I then copied over were the Roms and themes and Emulators. No XML or ini files were transfered.
Guess I'll start from scratch again and see how it goes.
Watch this space:cool:
Freshly installed HS with no intervention at all. Still set with the original 1.0.48.2 Hyperlaunch. Totally untouched. And still the same issue as you can see below.
Everytime I try to open up a system it loads up the main menu.xml instead of the system one(MAME.xml for example.
06:43:07 PM | HyperSpin Started
06:43:07 PM | Going windowed mode
06:43:07 PM | Checking for updates
06:43:07 PM | Update Check Complete
06:43:07 PM | Startup program unavailable
06:43:07 PM | Playing intro video
06:43:10 PM | Error intializing joysticks
06:43:10 PM | Menu Mode is multi
06:43:10 PM | Loading Main Menu.xml
06:43:10 PM | Main Menu.xml successfully loaded
06:43:11 PM | Main Menu wheel loaded successfully
06:43:26 PM | Loading Main Menu.xml
06:43:26 PM | Main Menu.xml successfully loaded
06:43:27 PM | Main Menu wheel loaded successfully
06:43:34 PM | Loading Main Menu.xml
06:43:34 PM | Main Menu.xml successfully loaded
06:43:35 PM | Main Menu wheel loaded successfully
Could I have something not right in my comp system? Flash not right or something? I am now totally stumped:hmmmm:
BBB always mentions that you need a speaker setup or a sound card or something or other. To be honest, it's late over here and I can't remember exactly. Check your audio setup and make sure you've got something in place for your new PC. I'll search the threads more after I've gotten some sleep.
ZzZzZ...
<em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
I'm continuing to mirror Thommo's approach to reinstalling all the software, but I too can't shake the issues. Hypnoziz may be on to something with the sound card. I'm getting an error message there, I'll go ahead and reinstall the sound card and see if that fixes the issue
Nice catch Hypnoziz, forgot about that one. Make sure you have a sound driver installed and speakers plugged in. Having speakers is especially important from memory (its late here too).
Just reloaded the audio card and driver and it immediately fixed the issues. No need to reintall the Hyperspin software and MAME.
I hope this fixes your issues too Thommo.
Yep late here too :P
Well that might make some sense seen as though I havnt bothered setting up the sound card as yet!
Will let you all know how I go tommorow when it isnt so late. Not that I will sleep knowing that there is something to try now.
Thanks guys in advance. Hope it works.
sounds like I have the same issue. Looking foward to getting HS pumping away.
I must not have understood your problem then, I thought you were having an xml issue, not a sound one.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
It appears that the 'sound issue' was actually creating the larger issue of the escape and enter keys not working to access the emulators. Guess a 'cause and effect' situation. Thanks for all the help!
Well there you go!!!!!!!(as you can tell I couldnt sleep :P)
Installed Sound driver and now all works peachey again.
Who would have thought that sounds would impact on the way HS operates.
As they say "everyday is a school day"
Thanks a bunch for all the imput and help.
djvj
What JBENSIN26 said.:dito:
Cool, glad you guys got that worked out. When I format, HS is the last thing getting put on so I have never come across something like that, nor have heard of HS being affected in that way. Learn something new everyday.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
  • 1 year later...
  • 1 year later...
I know this thread is long dead, but I'll follow up anyways.
I had the same problem, but it was fixed when I plugged in a pair of headphones into the jack. I didn't have any speakers hooked up (because I'm setting up the software before I move the machine into my cabinet)
  • 5 months later...
I have copied my setup to many different systems with no problems.....Except for once...make sure your audio drivers are setup and speakers plugged in.......otherwise Hyperspin will only load the menu.xml over and over....Hope this helps
ZzZzZ...
This worked for me. I was having the same problem and I searched like a mad man. Finally after several key word attempts and after reading this I plugged my speakers in and poof everything works again. Thanks Hypnoziz!!!!
  • 10 months later...
