NEC PC Engine-CD/RetroArch Help
Emu54
Hi I have set up NEC PC Engine-CD with RetroArch my rom collection are zip inside CCD IMG SUB RetroArch don't support ccd whats best way around this is there a app to make cues or is it redownload a different set
  • Replies 61
I tried setting this up this morning but get an error from HL asking for the syscard3.
Anyway, my images are cue and iso and the cue file loads manually in Retroarch. Have you tried running the game in Retroarch? An alternative to downloading them again would be to convert if possible or try another emu, which probably has it's own problems; Magic Engine I'm looking at you :)
syscard3 yup bios got that put in Retroarch folder with other bios worked because u need it for PC Engine had this same prob with my neo geo cd but downloaded them again think convert be best not sure what converter to grab
Yeah I put that file in the system folder but still no joy. I'll figure it out.
Your quickest course of action would be to get the Hyperspin ready set off of PD @ 38gb.
Ok got working with mednafen the syscard3 goes in firmware and it mounts the ccd file :) no controller settings what I can see of
The PD pack is true rip, so its in ccd, img, sub; doesnt work with retroarch. I got the same problem with the last git version of retroarch... even with de syscard in the correct directory, the module cant find..... changed back to a previous version and worked. I think that the problem is the module.
I also tried to find a way to convert ccd/img to cue/bin but it's a dead end
Tried the same with ultra iso..... the solution for me was to download games iso +cue. Now i have the full set sega cd, pc engine cd and turbogafx cd in iso, cue format.
Humm tryed that i got a couple of games from EP they was iso and cue did not work for me must of missed something
There was an error waiting for the window "RetroArch ahk_class RetroArch". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem hummmmmmm
If you don't already know, that usually comes up because the emulator hasn't started or your using the wrong emu or version.
I had the same problem so I tried Ootake for the emulator and it works. You just have to make sure you follow the few notes in the AHK file so everything syncs up.
Got a few systems on my RetroArch don't really want to change version plus downloading each rom separate take a while the roms i have are the ccd img sub from PD i tryed Ootake getting some info about ram not sure what to press
Mednafen added ccd support a little while back, so if you use a new enough test build of RetroArch and the core it should be able to load those. I haven't tested that format with pce_fast myself yet though (I tried one with the PSX core and it worked). My PCE CD rips are in bin/cue or iso/cue and have no problems.
Your correct, I downloaded 1 archive from the set on PD, Bomberman. Retroarch saw the ccd file and loaded it no problem. I use v1.0.0.2.
Tells me that ccd is not supported
True, you'll need to edit the module so it can work with .ccd instead.
Firstly backup the module.
Open the RetroArch.ahk in notepad++
Find line 183, which is (Edit, see following. Should be line 150)
{ If romExtension != .cue
Change it to
{ If romExtension != .ccd
It does work.
Still no look my Module has a ! in hyperlauch hq invalid crc made a copy
If you edit any module you get that, but it doesn't stop you using it. If it bothers you though, you'll have to either wait for an official release or you may have to ask for it to be added.
