andyco40 Posted October 20, 2014 Posted October 20, 2014 hi all just got a u-trakball but cant for the life of me how to wire it up for left and right buttons on my control panel any help please thanks .
dougan78 Posted October 20, 2014 Posted October 20, 2014 If you go to the utrak page there is a pic with how to wire up. I have the USB connection and was able to get it all connected up fine. What is your issue exactly? You don't know which wire to use for the buttons? If I remember right on mine there was an open spot on the connector and I had to add a wire for one of the buttons. I can double check my cab when I get home if you still need assistance.
gigapig Posted October 20, 2014 Posted October 20, 2014 The page at Ultimarc says this The black wire shown arrowed in the above picture is not used by the trackball. This is the left button connection.The unused contact next to this is the right button connection.. The COM terminals of the mouse button switches should be connected to a convenient ground point (Eg an I-PAC ground, or PC casing).
andyco40 Posted October 20, 2014 Author Posted October 20, 2014 yep the black I av seen that but tried it and not working plus my ground on my button is connected to my ipac ground. plus it says The unused contact next to this is the right button connection I have a red wire there I wish they would make the intructions clear with diagram.
andyco40 Posted October 20, 2014 Author Posted October 20, 2014 Done a work around I've done ahk file .exe with the buttons I wanted to use as left and right and put it in start up with pc and that seems to work ok.
