eezetee Posted November 7, 2014 Author Posted November 7, 2014 So you had started that machine up without the USB receiver plugged in, then when you plugged it in the aimtrak changed? I assumed once you boot up with the usb receiver in, the ID's stay the same as the actual controllers are hidden from the USB bus by the receiver. Will see if I can find a reasonably priced 360 controller this weekend. All the windows versions come with the USB receiver right?
connorsdad Posted November 7, 2014 Posted November 7, 2014 So you had started that machine up without the USB receiver plugged in, then when you plugged it in the aimtrak changed?I assumed once you boot up with the usb receiver in, the ID's stay the same as the actual controllers are hidden from the USB bus by the receiver. Will see if I can find a reasonably priced 360 controller this weekend. All the windows versions come with the USB receiver right? The aimtrak id changed on the initial bootup to account for the new device (wireless adapter). Once everything was reconfigured to accommodate this, all my controller ids now stick
damageinc86 Posted November 7, 2014 Posted November 7, 2014 So is the moral of the story to leave everything plugged in?
connorsdad Posted November 7, 2014 Posted November 7, 2014 So is the moral of the story to leave everything plugged in? Yes, if you find an Id has changed just reboot. I'd say 1 out of every 6 bootups has an id that has changed on my cab, I reboot and everything is fine again.
eezetee Posted November 7, 2014 Author Posted November 7, 2014 Strange that even 1 out of 6 reboots, with everything always plugged in would it change. I would think that won't setup, plugged in and no new devices, that the ID's should stick. I'll known soon enough, my 360 controller arrives tomorrow
eezetee Posted November 8, 2014 Author Posted November 8, 2014 Thanks everyone. Went out and bought 2 xbox wireless (windows) controllers. Both controllers paired to a single WiFi Receiver (so I've got a spare receiver). Set up MAME (as a test) with both the arcade buttons and the controllers in the mappings. Both worked fine. Did a reboot and the controller ID's stuck. Even swapped out the batteries as a test and seems all is good. Glad I can put this issue down know. Now I need to get familiar with the xbox controller
