dark13 Posted November 2, 2014 Posted November 2, 2014 Hypertheme does .zip the themes but if you make some modifications to a theme trought winrar and then try to open it in hypertheme it will give an error. Is there some winrar parameters of another archive software compatibile with hypertheme? I need to modify .XMLs inside themes for aeon nox as hypertheme does not support >2000 on X position for an artwork layer and scrolling text .swf need this kind of positioning (finally I realize why trnzaddict aligned text on the right in his .swf ). Is there a workaround for this problem? Themes with >2000 positioning on X axis works flawlessy in hyperspin but if I manually modify .xmls they will not be no editables in hypertheme... Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
dark13 Posted November 2, 2014 Author Posted November 2, 2014 Ok, it seems I can use 7zip for this, thank you very much Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
