Old eeepc, monitor help.
xHyperSteve
Dude im in the same boat steve, I have a perfectly good 17 inch laptop monitor that I cant use. Its only like 27 wires, and ive done my fair share of soldering.... but screw that
I was about to ask what the cable looked like. If it was a ribbon cable from end to end I would have said you are screwed. But that cable. Is doable. Extending that round cable. Would still require soldering but much easier to do and much less pain.
Why are you. Talking like. William Shatner? :)
Just buy a new monitor or a refurbished one. By the time you're done buying all the supplies you need and look at the amount of time required, you might as well just spend the money on a proper monitor.
I once wanted to build a steering wheel for my PC. When I was done adding up all the components, it would have been more expensive than buying a refurbished Logitech Momo wheel so I bought that instead.
  • 5 months later...
