BlueGoblin Posted December 14, 2014 Author Share Posted December 14, 2014 yes i updated w/ the firmware to v3 Link to comment Share on other sites More sharing options...
gigapig Posted December 14, 2014 Share Posted December 14, 2014 The one you have photographed is not a Nintendo Wiimote, the screws are philips head screws, they should be tri wing screws, it's missing the label with the serial number and has a bad QA sticker over the other screw. Here are three of mine, White is an original Nintendo (see the sticker with the part number) the red one works fine, the black one (I just found out) will sync if mode 1 is selected, but as soon as I change that to mode 4 it loses sync and goes off. The red and black are both cheap copies. Link to comment Share on other sites More sharing options...
randr Posted December 14, 2014 Share Posted December 14, 2014 Good grief are those nice looking knock offs! Well I bet that's why he's having so many problems Link to comment Share on other sites More sharing options...
BlueGoblin Posted December 15, 2014 Author Share Posted December 15, 2014 will the Wii U remote work? Link to comment Share on other sites More sharing options...
randr Posted December 15, 2014 Share Posted December 15, 2014 Yes official wii u will work with dolphin bar Link to comment Share on other sites More sharing options...
randr Posted December 16, 2014 Share Posted December 16, 2014 Any progress to report? Link to comment Share on other sites More sharing options...
BlueGoblin Posted December 19, 2014 Author Share Posted December 19, 2014 i now have a new wiimote with the motion plus built in. I have the dolphin bar set at 4 and when i try to sync the wii mote w/ the dolphin, the wii mote is only setting at the first blue bar only. shouldnt it be the 4th blue bar? Anyways its still not working. Suggestions? Link to comment Share on other sites More sharing options...
gigapig Posted December 19, 2014 Share Posted December 19, 2014 The Dolphin bar is supposed to simplify things. So you press the sync button on Dolphin bar, you open the battery compartment of your newly purchased Wiimote and press sync. Once synced you then press the mode button till mode 4 is selected. Job done, play Wii games on your PC. You can also change the mode on the fly by pressing the Home button and a direction on the D pad. Link to comment Share on other sites More sharing options...
BlueGoblin Posted December 19, 2014 Author Share Posted December 19, 2014 Yes i tried both ways...when holding the red button only. the solid blue light at the bottom lights up (the first one) when i hold the red button and buttons 1 & 2 at the same time, the first and second button light up in blue at the bottom end result - still not working. can somone log into my system and see what i have done wrong - please? Link to comment Share on other sites More sharing options...
boomerps2 Posted December 31, 2014 Share Posted December 31, 2014 Does your wii remote vibrate after syncing in the Dolphin Emulator. Mine will vibrate after syning and the lights on the wii remote will light up player one through four as if it's connected to an actual Wii. Link to comment Share on other sites More sharing options...
gigapig Posted December 31, 2014 Share Posted December 31, 2014 We did work out over pm that the Wiimote is connected to the Dolphin Bar, but was not working in Dolphin. Link to comment Share on other sites More sharing options...
BlueGoblin Posted January 4, 2015 Author Share Posted January 4, 2015 yes correct Link to comment Share on other sites More sharing options...
damageinc86 Posted March 4, 2015 Share Posted March 4, 2015 Mine works great so far, synced right up. But what I can't figure out is how to update the firmware. The program says you have to do something with the sync button and the power button to put it into firmware update mode,...but i don't see a power button Link to comment Share on other sites More sharing options...
gigapig Posted March 4, 2015 Share Posted March 4, 2015 Mine works great so far, synced right up. But what I can't figure out is how to update the firmware. The program says you have to do something with the sync button and the power button to put it into firmware update mode,...but i don't see a power button You need to hold the sync button down and then plug it in, then the update button should light. There is a new firmware which came out on the 15th Feb, here are the notes. W010 Upgrade Firmware Ver04 Updates on February 10, 2015 1.The SYNC LED (LED 0) will be off if NO Connecting with the Wiimotes. The SYNC LED (LED 0) will stay lit if connecting with the Wiimotes. 2.The DolphinBar will not enter into the sleep mode while in the Mode 4 (Dolphin Mode) with Windows 8.1 (Some customers feedback this problem before) Link to comment Share on other sites More sharing options...
