Raccoon Posted January 4, 2015 Author Posted January 4, 2015 Ah, noticed your comment about flipper under the video now - perfect! Where, were, ware - it´s not my thing, don´t remember when to use which
craiganderson Posted January 4, 2015 Posted January 4, 2015 I was using the "Spelet fungerar inte" as a placeholder .png for the game that did not work the first time around. I had neglected to replace that .png after I fixed flipper with your new files.... ill add the two new ones in a minute.... http://craigandersonthemes.weebly.com/
craiganderson Posted January 4, 2015 Posted January 4, 2015 here is a real quick bezel http://craigandersonthemes.weebly.com/
Raccoon Posted January 4, 2015 Author Posted January 4, 2015 Are you sure you don´t speak Swedish? I mean how did you get up to "Spelet fungerar inte" and how do you understand how to control the games That bezel looks great, even a Swedish flag! Where, were, ware - it´s not my thing, don´t remember when to use which
craiganderson Posted January 4, 2015 Posted January 4, 2015 thanks google translate! http://craigandersonthemes.weebly.com/
Raccoon Posted January 4, 2015 Author Posted January 4, 2015 Do you know how that will work with a vertical screen? I have mine mounted vertical for better compatibility with pinball games like Future Pinball and for vertical scrolling arcade games like 1942, Terra cresta an so on. Where, were, ware - it´s not my thing, don´t remember when to use which
craiganderson Posted January 4, 2015 Posted January 4, 2015 time for bed ill upload everything tomorrow have a good one.... http://craigandersonthemes.weebly.com/
craiganderson Posted January 4, 2015 Posted January 4, 2015 one last thing here is the module .ahk....if any module experts have any ideas to improve upon it ...please let me know but its working 100% on my system all games load from one click on wheel....all the way to the game starting i need to add fullscreen support tomorrow as well MEmu = MEmuV = MURL = MAuthor = craiganderson MVersion = MCRC = iCRC = MID = MSystem = "abc80" ;---------------------------------------------------------------------------- ; Notes: ; ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) BezelStart("fixResMode") SetCapsLockState, On SetScrollLockState, AlwaysOff Run(executable, emuPath) WinWait("ahk_class ABCWIN") WinWaitActive("ahk_class ABCWIN") Sleep, 100 WinMenuSelectItem, ahk_class ABCWIN, , Setup, Configuration... WinWait("Configuration ahk_class #32770") WinWaitActive("Configuration ahk_class #32770") ; loads selected game into drive 0 Loop { ControlGetText, edit1Text, Edit1, ahk_class #32770 If ( edit1Text = romPath . "\" . romName . romExtension ) Break Sleep, 100 ControlSetText, Edit1, %romPath%\%romName%%romExtension%, ahk_class #32770 } Sleep, 100 ; loads [OS] SYSTEM10.dsk into drive 1 Loop { rom2name:="[OS] SYSTEM10" rom2extension:=".dsk" ControlGetText, edit2Text, Edit2, ahk_class #32770 If ( edit2Text = romPath . "\" . rom2name . rom2extension ) Break Sleep, 100 ControlSetText, Edit2, %romPath%\%rom2name%%rom2extension%, ahk_class #32770 } Sleep, 250 ControlSend, Button1, {Enter}, ahk_class #32770 WinWait("ahk_class ABCWIN") WinWaitActive("ahk_class ABCWIN") ; centers emulator window WinGetPos,,, Width, Height, aahk_class ABCWIN WinMove, aahk_class ABCWIN,, (A_ScreenWidth/2)-(Width/2), (A_ScreenHeight/2)-(Height/2) ; types "RUN LIB" Sleep, 800 SetKeyDelay, 50 Send, {R down}{R up}{U down}{U up}{N down}{N up} Sleep, 10 Send, {Space down}{Space up} Sleep, 10 Send, {L down}{L up}{I down}{I up}{B down}{B up} Sleep, 10 Send, {Enter down}{Enter up} ; selects/types "D" for drive Sleep, 1000 Send, {D down}{D up} ; selects/types "0" for drive 0 (zer0) Sleep, 1000 Send, {0 down}{0 up} ; types "RUN" and then types the name of the rom/dsk file Sleep, 2900 Send, {R down}{R up}{U down}{U up}{N down}{N up} Sleep, 100 Send, {Space down}{Space up} Sleep, 100 Loop, parse, romName { Send, {%A_LoopField% Down} Sleep, 50 Send, {%A_LoopField% Up} } ; hits the ENTER button Sleep, 100 Send, {Enter down}{Enter up} BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() CloseProcess: SetCapsLockState, Off FadeOutStart() WinClose("ahk_class ABCWIN") Process, Close, ABC80.exe Return http://craigandersonthemes.weebly.com/
craiganderson Posted January 4, 2015 Posted January 4, 2015 Do you know how that will work with a vertical screen?I have mine mounted vertical for better compatibility with pinball games like Future Pinball and for vertical scrolling arcade games like 1942, Terra cresta an so on. i do not. sorry http://craigandersonthemes.weebly.com/
Raccoon Posted January 4, 2015 Author Posted January 4, 2015 One thing about the module, I just read the module code and now I understand what you meant in a early post about "system10.dsk" You dont have to type "RUN LIB" before you start another program, that is only to see the contents on the .dsk image. When starting a game it should be enough to just type "RUN GAMENAME" Where, were, ware - it´s not my thing, don´t remember when to use which
craiganderson Posted January 4, 2015 Posted January 4, 2015 One thing about the module, I just read the module code and now I understand what you meant in a early post about "system10.dsk"You dont have to type "RUN LIB" before you start another program, that is only to see the contents on the .dsk image. When starting a game it should be enough to just type "RUN GAMENAME" 1) regarding the system19.dsk thing....i dont know if its true or not. but module working 100%. 2) regarding RUN GAMENAME,...cool..ill update module http://craigandersonthemes.weebly.com/
craiganderson Posted January 4, 2015 Posted January 4, 2015 everything should be available for download please let me know if anybody has any problems/errors etc http://craigandersonthemes.weebly.com/ scroll down and click "luxor abc80" -craig http://craigandersonthemes.weebly.com/
Raccoon Posted January 4, 2015 Author Posted January 4, 2015 Most exsiting! Will download and test as soon as I can! Where, were, ware - it´s not my thing, don´t remember when to use which
craiganderson Posted January 4, 2015 Posted January 4, 2015 cool. let me know of any problems of course. and i announced the theme in another thread since it was kinda hidden in this one. just in case anybody else wants it http://www.hyperspin-fe.com/forum/showthread.php?38402-Luxor-ABC80-Full-Setup-craiganderson(20150104) http://craigandersonthemes.weebly.com/
Raccoon Posted January 4, 2015 Author Posted January 4, 2015 I hope someone will, your effort is worth it! Where, were, ware - it´s not my thing, don´t remember when to use which
