Styphelus Posted February 25, 2015 Posted February 25, 2015 Finally setting up Sega Naomi. Which emulator should I use? I've heard some say Demul, Makaron and even NullDC. Most of the stuff I've been reading is a couple years old. Just trying to figure this one out. My computer is a beast so I'm not worried about performance, just the one with best compatibility. Any recommendations?
vampirolatino2 Posted February 25, 2015 Posted February 25, 2015 I use Demul, it is working ok. ... and if your computer is a beast you will enable higher resolutions and shaders.
Styphelus Posted February 25, 2015 Author Posted February 25, 2015 What version of Demul are you using? Hyperlist was made for version 5.6 so that's what I had setup a while back but never really configured it properly. Is there any advantage to using a newer version of Demul? I have Demul 5.8 but it has a ton of issues with SweetFX shaders. Just wondering if 5.6 for Naomi is enough!
vampirolatino2 Posted February 25, 2015 Posted February 25, 2015 I will see what version I have and post it. SweetFX shaders, ok got it. Will check.
vampirolatino2 Posted February 25, 2015 Posted February 25, 2015 I have version 5.8.2 .. and there is 3 modules available (5.4, 5.6 and 5.8) I don't have that shader available. It is something you download extra?
Styphelus Posted February 26, 2015 Author Posted February 26, 2015 Yes, you can use SweetFX to add shaders to your emulators. I use a nice scanline shader for SSF (Saturn), NullDC (Dreamcast) and WinAUE (CD 32 and Amiga). Let me know if you want them and I'll drop them in the FTP for you. With Demul however, it stopped using DX9 in version 5.6 and SweetFX won't work with DX11 and Win 8.1. I got shadders working with it but they look terrible. I'll go ahead with Demul 5.8 than. I have a modified module that adds a bezel and I created bezels with scaliness. After a few tries, last night I finally created a good set of scanlines that look really close to the real thing. Guess I'll use that instead.
vampirolatino2 Posted February 26, 2015 Posted February 26, 2015 Yes, you can use SweetFX to add shaders to your emulators. I use a nice scanline shader for SSF (Saturn), NullDC (Dreamcast) and WinAUE (CD 32 and Amiga). Let me know if you want them and I'll drop them in the FTP for you.With Demul however, it stopped using DX9 in version 5.6 and SweetFX won't work with DX11 and Win 8.1. I got shadders working with it but they look terrible. I'll go ahead with Demul 5.8 than. I have a modified module that adds a bezel and I created bezels with scaliness. After a few tries, last night I finally created a good set of scanlines that look really close to the real thing. Guess I'll use that instead. Oh, that's why it isn't working in the 5.8 version... now I understand, thanks! Hope you get it to run at least to see it working. And I didn't know you could use those shaders with so many emulators. Cool! If you have it available and with an example of configuration so I can see what you see better! I will try them Weird, here it say it works for Direct X 9, 10,11 and Windows 2000 up here: http://sfx.thelazy.net/forum/sweetfx/2/
Styphelus Posted February 26, 2015 Author Posted February 26, 2015 Oh, that's why it isn't working in the 5.8 version... now I understand, thanks! Hope you get it to run at least to see it working. Weird, here it say it works for Direct X 9, 10,11 and Windows 2000 up here: http://sfx.thelazy.net/forum/sweetfx/2/ It doesn't work with windows 8.1 and DX11. Works fine with 7. Not sure if it ever worked with 8.
vampirolatino2 Posted February 26, 2015 Posted February 26, 2015 It doesn't work with windows 8.1 and DX11. Works fine with 7. Not sure if it ever worked with 8. Bummer, I have 8.1
optical Posted February 26, 2015 Posted February 26, 2015 i would like to add the noami in my hyperspin. does somebody have an xml for me? thanks
Dime333 Posted February 27, 2015 Posted February 27, 2015 i would like to add the noami in my hyperspin. does somebody have an xml for me?thanks http://hyperlist.hyperspin-fe.com/
shitoken Posted May 5, 2017 Posted May 5, 2017 On 2/26/2015 at 8:05 AM, Styphelus said: Yes, you can use SweetFX to add shaders to your emulators. I use a nice scanline shader for SSF (Saturn), NullDC (Dreamcast) and WinAUE (CD 32 and Amiga). Let me know if you want them and I'll drop them in the FTP for you. With Demul however, it stopped using DX9 in version 5.6 and SweetFX won't work with DX11 and Win 8.1. I got shadders working with it but they look terrible. I'll go ahead with Demul 5.8 than. I have a modified module that adds a bezel and I created bezels with scaliness. After a few tries, last night I finally created a good set of scanlines that look really close to the real thing. Guess I'll use that instead. This is a quite old post but interested to ask you if you are using sweetfx with sega model 2? can share?
Styphelus Posted May 5, 2017 Author Posted May 5, 2017 3 hours ago, shitoken said: This is a quite old post but interested to ask you if you are using sweetfx with sega model 2? can share? No. No need anymore. I just use the Rocketlauncher CRT overlay with it.
griffin518 Posted May 5, 2017 Posted May 5, 2017 I use DeMUL for Naomi as well, and never got SweetFX to work with the newer version. I agree with @Styphelus, using either the RL overlay or a bezel with the overlay built in is the way to go. If you need a bezel, let me know and I'm happy to give you mine or whip up something new. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
shitoken Posted May 6, 2017 Posted May 6, 2017 16 hours ago, Styphelus said: No. No need anymore. I just use the Rocketlauncher CRT overlay with it. I know how to use Bezel but never tried the CRT overlay thing in RL Is it under the same settings? Oh I forget to ask do you mean we do not sweetfx for any systems except SSF.
shitoken Posted May 6, 2017 Posted May 6, 2017 13 hours ago, griffin518 said: I use DeMUL for Naomi as well, and never got SweetFX to work with the newer version. I agree with @Styphelus, using either the RL overlay or a bezel with the overlay built in is the way to go. If you need a bezel, let me know and I'm happy to give you mine or whip up something new. Thanks mate if you share with me. its include the overlays?
