Noob help: Changing system wheel
How to i change out the default "system" wheel. I searched thru all my folder i can not find anything. And since this site upgraded forum the search option is limited. - thanks in advance
Yes, i have added custom themes, wheel to games to games before. Thanks in advance
What do you mean by changing "system" wheel?
Do you want to change the amount of games?
A system theme does not exist
The themes for the games are listed in .\Hyperspin\Media\Main Menu\Themes
Alain are you referring to which system wheel hyperspin starts with??
I always thought it starts on the system that was last run.
E.g. If you run Mario bros on nes then exit hyperspin.... Next time you run hyperspin it will choose the nes wheel.
The wheel art for the emulator systems
If you are referring to the wheel image used in the main menu wheel where you pick the system, the it is in \Hyperspin\media\main menu\wheel images\
Lots of the Wheel art can be found on the FTP server from Hyperspin.
But i think you need to be some member to get access to it. Like: silver gold or platinum member.
