Sega cd not seeing games?
demonseed
Guys
I tried fusion and my sega cd games load up fine. I setup hyperspin but the games do not show? I downloaded two sets of hyperspin 1 compatible games. To me the database is not working? I even tried my old setup of games that worked with old hyperspin but now they won't work? Any ideas? When I google it others had same issue on old forum... Can I access old forums too? How?
Thanks
Jim
Run dons hypertool to make you a new list... Do these mega cd contain bin/cue ?? Then choose only file extension in that program (cue) create list.. In hlhq add "cue" only in file extension.. Try
Skickat från min iPhone med Tapatalk
Hey
Ok.. I got the list generator to list all the games and I can add them to a xml, however where do I set the CUE thing? It scans all the games says 171 of 171,.. I hit export and save xml.. however when I open the xml it only lists this
<?xml version="1.0"?>
<!--Generated by Don's HyperSpin Tools version 4.2.6-->
-<menu>
-<header>
<listname>Sega CD</listname>
<lastlistupdate>08/28/2012</lastlistupdate>
<listversion>1.2 Final</listversion>
<exporterversion>HyperList XML Exporter Version 1.3 Copywrite © 2009-2011 William Strong</exporterversion>
</header>
</menu>
Hey
Ok I used the app Dons hyperlist generator and now it shows the games in the xml, however in HL it still is red? I renamed the file to sega cd in my database folder... not sure why I can not get them to show... they work fine in fusion when manually loaded. In HL it shoes the list in red, when I hit the blue triangle to compare it says I have 0 of 171. So the database is not seeing my roms. Retroarch/fusion are set to cue. Is it dameon tools?
In hyperlaunchHQ.. In Sega Cd ... Add your emulator name, Path to the exe file, file extension (cue) if u have bin/cue files... And module.. (Fusion 3.64)
I did sega cd is XML name in database folder. Is there a walk through must be something I am doing wrong.
... Or use it as a global emulator... Just check global emulators.ini file... Search for fusion 3.64 and check if u have correct file path in those lines...
So database folder name: Sega CD ... Database name: Sega CD .. Try
Hey
Ok.. so I have checked.
Hyperspin/Databases/Sega CD
Emulator is under Emulators/Fusion/Fusion.ex
Roms are Emulators/Fusion/roms.
Roms are CUE and BIN from what I can see.
Fusion is set to 7z|zip|sg|sc|gg|sms|gen|32x|md|cue|bin for extensions globally.
No idea what the issue is.....
Teamviewer? is there something I can post here to get help?
I have tried the ROM RENAMER tool but when I open the OFFICAL SEGA CD database xml file it errors out saying no CRC located. I think it has to do with the actual naming of the roms.... just not sure how to change. When I look at the Sega CD.xml file,,, it has 3 Ninjas Kick Back (USA) Listed for the game, while in my rom folder it has 3 Ninjas Kick Back (1994)(Sony Imagesoft)(NTSC)(US)[CDAC-078200 2].... that would be why. I need to rename them all to match? not sue how to do it. I tried manually and then the ninja game showed green in Hyperlaunch but it still wont run, as I think renaming it manually doesn't work.
With teamviewer i can view/control your computer with an easy login.. And try to help you out
this is your problem
your game names should match the XML
this should be renamed to
if your games are 7z compressed,  you only need to rename the 7z file -->  3 Ninjas Kick Back (USA).7z
and enable 7z support.
if your roms are not compressed,    you ONLY need to rename the CUE,  you should not rename your BIN file.  if you rename the BIN file; the CUE file will be broken and will need to be updated.
if you have your roms in sub folders,  you will need to rename your sub folder to match the XML name.
your final file should look like this
3 Ninjas Kick Back (USA)/
3 Ninjas Kick Back (USA).CUE
3 Ninjas Kick Back (1994)(Sony Imagesoft)(NTSC)(US)[CDAC-078200 2] .BIN
so all the cues need to be renamed... tu matcher renamed all bins but not cues... is there a app to do this?
The cues need to be renamed yes. If you renamed the bins you will need to open each cue for each game with notepad or similar program. Then change all the file names in there to match how you named them. Good luck.
I thought a hyperspin ready set wasnt needed to change anything... Hehe!
Well if u need My help through teamviewer, i can do later tonight. It's 6:34 a.m now and work is calling.. So like 17:00 +1.00 gmt
SOLVED!! I renamed all the CUEs to the way I was told and it works (with fusion).. (although the set I got is no quite complete)... Also in fFusion when I boot I get white text in bottom right saying Sega Cd built in ram, sega cd shutdown, loading ram, and something else.. how to disable it???
Thanks so much!! I appreciate your help
