HSBezel
knewlife
I originally added the app, since it's now it's just go to the download page as if you were downloading it. There is an edit link aka button that you should see in the top right corner I think which is close to the green download button for the app. From there just say it's version 2 and upload the zip file. Push submit at the bottom of that screen and you are done. I need to check this out more though. So this app allows you to create ini for all ur bezels at once or individually? Maybe you could create a quick video to go along with your instructions above
Tapatalk signature
  • Replies 60
Awesome, thanks a lot man!  Going to test it in a few hours.  Have you ever looked into if you are able to keep HS in the bezel permanently even when some weird games exit and try to move it?  Or have you dealt with that already?
Does this have to be in the root directory  now?  Because all I get when running it is the bezel, hyperspin doesn't start.  But it's in the folder "HSBezel" within the Hyperspin directory.
yes the exe has to be in the root hyperspin folder and the bezels must be located in the HSBezel folder. And yes it deals with apps moving Hs around.
Tapatalk signature
No it just display a bezel around hyperspin so it can maintain its original aspect ratio and keep it centered in screen. Just have to copy the app to the Hs root and execute it... It should work. Then you can customize the bezels.
just to verify, the shelling of windows you did is a totally separate thing than this
Also ni your instructions, all the links are dead
Finally, I use ghutches start up script to launch number of apps along with hyperspin, would I need to recompile etc like your instructions are saying to get all those apps running at the same time as well? just trying to get all my info before I try this
thanks
thanks
You can downlaod it from here: http://www.hyperspin-fe.com/files/file/7425-hsbezel/   ( HSBezel2015-12-15.7z )
And you can launch any application or none if you wish by modify the ini file
  • 4 years later...
Quote
Every time HS Window is active AND the position of the window or the bezel has changed they will be centered again.
This normally happens when enter an application that changes monitor resolution. This problem dont exist when runing HS in full screen,
but remember we are in Window mode here.
The application can not be used adequately? Even the MAME emulator does not work.
Sorry for my English.
  • 7 months later...
I tried with HS 1.5 and it works fine but only for default theme, I created the structure in the same way as the bezel pack but at the change of system the bezel does not change
  • 2 months later...
AutoHotkey.dll
If your Bezels won't change, take this dll and place it into your HScript folder where the HScript.ahk is (Hyperspin/Scripts/HScript for example).
I read a comment by Marco Terracciano about this as I watched a video on Youtube by Planet Geekdom. So thanks Marco!
